I wonder if Gorilla Glue would be a good alternate filler? I just used it to repair a surf board ding; it expands into a rigid foam, and if you tape over it with blue tape, the expansion is controlled. Sands beautifully when dry, and I would imagine the glue would hold together the two sides of the crack to help prevent further opening over time.
Cracked Dash Repair 101*
I wonder if Gorilla Glue would be a good alternate filler? I just used it to repair a surf board ding; it expands into a rigid foam, and if you tape over it with blue tape, the expansion is controlled. Sands beautifully when dry, and I would imagine the glue would hold together the two sides of the crack to help prevent further opening over time.Comment
Looks better than cracked that's for sure. I can see doing it when dashes are pricey, 240z dash for example goes for $800-1000 uncracked, last time I pulled one it cracked on the way out, same thing happened to my uncle last year.
However e30 dashes typically trade at the $80-100 level, may be a worthwhile investment for others (I know you said yours was out anyway, I understand your reasoning).
Here's an in-depth how-to from a 240z guy,
to
Originally posted by bluntcan you get me a deal on cases of their (fiji) bottled water? i wash my 02 in that shitComment
Not bad for less than $50.00 and a few hours. Good Job!!FEEDBACK:
http://www.r3vlimited.com/board/showthread.php?t=316212
BMWCCA #398608
IG @yagayo38
"The Best E30's were built with two camshafts four cylinders and sixteen valves!".Comment
My Build Thread Here (E30) ---> http://www.r3vlimited.com/board/showthread.php?t=240528
And Here (2002tii) ---> http://www.r3vlimited.com/board/show...35#post3173435Comment
Bump!
Anyone know if there is a way to treat a good dash so it doesn't crack? I replaced my dash a few years ago and it cracked when the weather got really cold.. and then another during the summer in the hot weather. I imaging that the cracking comes from expansion and contraction of the plastic. Gah!Comment
Wonder what it would look like if i did this but painted it brown to match the vinyl interior of my E30Celebrating 30 years.
1986 E30 Coupe, assembled in Munich, West Germany, 7/7/86. M10 5 Speed cruisin' through time and spaceComment
The only problem is what you used to fill in the gap
Super glue becomes very hard when it dries
Which means the next time the dash expands, the super glued part won't expand and you'll get more cracks
I used a black silicone tube from home depot
It's called " red devil premium elastomeric acrylic latex sealant"
It stays resilient after it dries
And it's black so it won't show through the black paint like the baking sodaComment
dude, can you provide closeup pics of your repair? kinda pointless to do a writeup and have pics from 10 feet awayRenting my rear wheel bearing tool kit. SIR
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
My buddy told me one reason the dashes crack in e30s is because the engineers made the dash a little too big for the car so when the chassis flexes it cracks. I think thats what he said, not sure if its true. IDKYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1989 BMW 325i SOLD
1998 BMW Estoril Blue e36 M3/4/5 SOLD
1987 BMW 325 (The Piece) SOLD
1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207Comment
he's an idiot and doesn't know the heat/cold/UV limitations of plastic.Comment
No need to insult his intelligence, this was a long time ago and I can't remember if thats even exactly what he said.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1989 BMW 325i SOLD
