Find Nissens, 94172 A/C Condenser 64538391509NIS at discount prices in our extensive BMW auto parts catalog. AutohausAZ offers a large selection of Nissens parts online. 1 per car. Fits BMW 325i, M3, 318i, 325e, 325is, 325iC, 325iX, 325, 318iC. 64531371843 64531375205 64531466050 64538391024 64538391509 94172
If you can track it down R-414b, dupont came out with a direct swap for R-22. You dont need to change the condenser, evaporator, metering device or the compressor. Im running it right now and it works great.
So, my old r12 dryer had two pressure switches. My new 134a dryer has only one switch. should i just double up the wires both going to the same switch?
Everything else is done so i'm stoked to get this thing charged.
Ok, I've got a High+low pressure switch in one housing from an E36. Pic attached here. Which connector is the high switch and which one is the low switch?
Thanks
Check for continuity, the low pressure would be open circuit with the switch uninstalled. The High would be closed.
