The Detailed E30 R-134a Conversion Thread/DIY
  • Falconer
    • 156
    #136
    Originally posted by glucklich21
    AutohausAZ has a PF condenser for $103 shipped, it's cheaper than the old Behr replacement and is a drop in replacement.d.
    Is this it? The Nissens one?
    Find Nissens, 94172 A/C Condenser 64538391509NIS at discount prices in our extensive BMW auto parts catalog. AutohausAZ offers a large selection of Nissens parts online. 1 per car. Fits BMW 325i, M3, 318i, 325is, 325e, 325iC, 325iX, 325, 318iC. 64531371843 64531375205 64531466050 64538391024 64538391509 94172
    1981 320is, Alpine White, 5 speed (Sold)
    1992 318is, Brillantrot, 5 speed (Sold)
    1996 328i, Montreal Blau, 5 speed (Sold)
    1991 325i Coupe, Alpine White II, 5 speed (Current)
    • glucklich21
      • 1912
      #137
      Yes.
      • Falconer
        • 156
        #138
        Prompt answer, A++ service, would post in OP's threads again.
        • glucklich21
          • 1912
          #139
          lol
          • colton135
            • Mar 2013
            • 13
            #140
            If you can track it down R-414b, dupont came out with a direct swap for R-22. You dont need to change the condenser, evaporator, metering device or the compressor. Im running it right now and it works great.
            • jrobie79
              • Mar 2006
              • 2526
              #141
              is that the cheapest people are finding for a condenser? $100?
              1991 318i ---- 308K - retired
              • 997_rich
                • Feb 2013
                • 48
                #142
                So, my old r12 dryer had two pressure switches. My new 134a dryer has only one switch. should i just double up the wires both going to the same switch?
                Everything else is done so i'm stoked to get this thing charged.
                • 997_rich
                  • Feb 2013
                  • 48
                  #143
                  further pics of my pressure switch question.
                  • Dj Buttchug
                    • Jun 2010
                    • 7672
                    #144
                    Just finished installing all my ac parts as well as the PF condenser. Im running the stock aux fan. Charging up tomorrow will post results
                    Turbo M42 Build Thread :Here
                    Ig:ryno_pzk
                    I like the tuna here.
                    Originally posted by lambo
                    • uturn
                      • Dec 2010
                      • 1001
                      #145
                      That connects to another pressure switch. pre-'91 e30s had two separate switches.
                      • 997_rich
                        • Feb 2013
                        • 48
                        #146
                        Ok, I've got a High+low pressure switch in one housing from an E36. Pic attached here. Which connector is the high switch and which one is the low switch?
                        Thanks
                        • kickinindian
                          • 2327
                          #147
                          hmm might go that route 0.0
                          or this stuff http://www.redtek.ca/
                          • caesar101
                            • Sep 2011
                            • 16
                            #148
                            Thanks
                            Check for continuity, the low pressure would be open circuit with the switch uninstalled. The High would be closed.
                            • Mad Chemist
                              • Nov 2011
                              • 226
                              #149
                              Here is the updated link for the A/C fan http://www.ebay.com/itm/14-Reversibl...item4848d46e8c
                              • Dj Buttchug
                                • Jun 2010
                                • 7672
                                #150
                                just finished charging my system after installing the new parts. This is the coldest AC EVER!
                                At idle my vent temp is 36 degrees.
                                Ig:ryno_pzk
