Had the exact same problem with the Nissens condenser I bought. Figured it would be easy enough to just unbolt the bottom plate, flip it and re-attach, except that one of the soft aluminum studs broke off while unscrewing the nut. Problem was I painted it black before I realized the issue so could not send it back. Ended up Flipping the bottom bracket and JB welding the plate back in place on the broken side, works fine but annoying that this seems to be a common issues with these.
The Detailed E30 R-134a Conversion Thread/DIY
'86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
Albie325 Build Thread | Albie325 COTM Jan 2021 -
The expansion valve is NLA. FCP Euro has this one as possible cross reference. Anyone verify this works?Comment
You have a Seiko Seiki 6452-1386-464. The Seiko Seiki part # is SS-811PB3. I have the same compressor and am not sure if it was original with the car. I was hoping to find a re-manufactured r134a compressor as part of a proper conversion.I apologize for the bad pictures. I need to replace or rebuild the compressor on my Touring. Does anyone know which of the E30 compressors is pictured below?
Thanks, Cory
AC Compressor 1 by cory58f5, on Flickr
AC Compressor 2 by cory58f5, on Flickr
Did anyone source a replacement for a Seiko Seiki 6452-1386-464 that didn't require modification to the mounting bracket or fittings?Comment
Thanks for the response! I actually took some clearer pictures and forgot to post them. Bad news that I have a Seiko. Was planning to have Jay Stratton rebuild it but he doesn't do Seikos. I've also heard good things about Polar Bear in FL, so it looks like I need to give them a call. I ordered all new hoses but now I wonder if the replacement will fit this compressor.
Cory1992 325i Cabrio
1988 320i Touring
2000 M5
1977 530i
2015 328i - Euro Delivery/Performance Center Delivery
BMWCCA
E30CCAComment
Funny you mention Polar Bear... I ordered the shaft seal kit for the Seiko Seiki SS-170 which according to Polar Bear is also compatible with the SS-811PB3, Polar Bear's part number is SS-0842.Originally posted by cory58
Thanks for the response! I actually took some clearer pictures and forgot to post them. Bad news that I have a Seiko. Was planning to have Jay Stratton rebuild it but he doesn't do Seikos. I've also heard good things about Polar Bear in FL, so it looks like I need to call them.
CoryComment
I am doing the r134 conversion on my 1984 318i. Can anyone assist on how to wire the new pressure switch?
Or should I keep the old setup low/high switch with old dryer?Comment
I would appreciate your' opinion on this fan model:
SPAL KÜHLERVENTILATOR 2140M³ BLASEND D382-D350 T=63 / VA08-AP51/C-23S 12V
Link: https://www.rennsportshop.com/de-top...m-blasend.html
It is in German, but you can make out the details. It is a 382 mm diameter fan (15") so it should fit correct? i have seen users running a 16" fan on the condenser. It is a push type fan with 2,140M3 capability, 12v and 9.9amps. I have already done the conversion last year (Nissens parallel flow condenser, cleaned out the hoses, new o-rings, expansion valve and new drier/receiver) but there is a tiny leak at the expansion valve, i emptied the system getting ready for repairs.
I could also order the Spal mounts, they come in various sizes (19mm, 28.7mm, and 58.6mm), i would be keeping the factory radiator/water pump fan and electrical system, already have a lower temp. switch on the radiator as well as a lower thermostat (it gets well over 40c/100F in summer here).
My understanding is that the functionality of the system is the same whether you have the one or two switch set up. I kept the two switches because I could not get a solid answer on wiring the single switch. Just replace the dryer every time you open the system.Last edited by cory58; 06-19-2020, 01:50 PM.1992 325i Cabrio
1988 320i Touring
2000 M5
1977 530i
BMWCCA
E30CCAComment
Since i had a leak in the system as well as some broken recirculation flaps and signs that the heater valve is leaking, i decided to remove the dash and the HVAC box and re-do the the whole HVAC system again.
I was researching again on the correct oil and filling capacities for the Seiko Seiki compressor and i am getting conflicting values.
When comparing to the chart listed here, some websites mention PAG 100 oil for this compressor with 200g capacity. Other websites show PAG 46 oil with 160-170g. Some include the BMW oil part number, some do not. The R134a filling capacity ranged between 900g and 1000g. It is getting a bit confusing, since even the remanufactured/rebuilt compressors for the Seiko Seiki are also conflicting between those values (PAG 100 for some, PAG 46 for others). I currently have PAG 100 in the system, but i am willing to drain and flush it again for PAG 46 if it is the correct one. I even came across some E32 posts with the same compressor, also conflicting between PAG 100 and PAG 46.
I am uncertain at this point on what to do, which oil viscosity and fill capacity? Any advice would be appreciated.Comment
I am thinking about doing this on my '89 315iX (M20) soon and I wanted to run a few things by the crowd here to hopefully minimize mistakes.
I have a compressor on the car right now that the PO said is shot (belt is off). He also gave me a Seiko-Seiki SS-811PB3:
Will this compressor work?
I'm looking at the following parts:
Condenser: https://www.rockauto.com/en/moreinfo...13&jsn=122
Expansion Valve: https://www.rockauto.com/en/moreinfo...1913&jsn=12188
Receiver Drier: https://www.fcpeuro.com/products/bmw...hr-64538391025
Pressure Switch: https://www.autohausaz.com/pn/64538390971
O-rings and adapters: https://www.autohausaz.com/pn/10161106-559807901
Based on the chart I think I need ISO 100 PAG oil.
I don't know what to buy for an electric fan - I saw some people talking about https://www.amazon.com/gp/product/B009OBOKI4 this fan, but it says it is only ~1000 CFM, which isn't half enough according to the original post.
A lot of the parts I see seem to be good for manufacture dates through 8/89. What changed then, anyone know? I'm not sure what month mine was made...
Am I on the right track here or do I need to change anything?Last edited by Chebyshev; 07-07-2020, 02:14 PM.Comment
The parts you listed seem to be in order, with the exception of the O-Rings and adapters, i purchased 8 O-rings of every size directly from BMW, was a bit pricey (costed me around €40) but saved me the headache of dealing with incorrect sizes.I am thinking about doing this on my '89 315iX (M20) soon and I wanted to run a few things by the crowd here to hopefully minimize mistakes.
As far as my research shows, your compressor is similar to mine and they do take PAG 100 oil. The only "issue" is the total quantity in the system, i am still getting various values from 160cc to 200cc (around 5.5 ounces to 7 ounces). The biggest change for late model E30 AC system is the updated pressure switch, mine is a 1990 model and i did not require to do any modifications, it was already updated from the factory with both high and low pressure switches in one switch/part.
Regarding the fan, i believe the factory fan is rated at 900 CFM give or take, the size would fit nicely the flow is on the low end. I just picked up a SPAL 14" (360mm almost) push fan rated at 2,140 CFM, i found numerous threads on this fan being a bit loud but cools great for the R134a conversion.
I hope this helps.Comment
Hi Forum Members,
Cory
It has been so long since I joined, And I just saw this post from Cory.
Sorry I could not help him.
So I wanted to explain why, I do not rebuild Seiko/Seiki's any more.
I used to rebuild them, but no more, they are just a Cheap Disposable Compressor by S/S and also made by Calsonic, both are JUNK.
The internals of this Wingcell copy, was changed to save money, BMW had S/S and Calsonic delete the 4 impeller bearings,
so with no internal bearings around the impeller, their REBUILD, caused me so many headaches, and unhappy customers.
I Finally quit rebuilding them.
Were as the Wingcell is built so well, it is a good candidate for a rebuild,
Good Luck, this is a Great Writeup,
P.S> I also rebuild the Denso Compressors from the 10P family. The 10P13/15/17, all 3 types.
Best, Jay Stratton
jay_c_stratton@hotmail.com
jaycstratton9@gmail.com
Jay Stratton
'88 m6 Red/Tan
Link to my 16 websites
https://www.bimmerforums.com/forum/s...rrent-websitesComment
Jay - Thanks for posting. I figured from your web site that the Seikos are junk and understand why you do not rebuild them.
Hi Forum Members,
I do have a follow-up question for the group: How difficult would it be to convert to one of the other compressors? The car in question is a 1988 320i Touring. I've never been clear on how BMW decided to put which compressor in which model. Are they like the style 5 wheels and sport seats - multiple manufacturers making the same part to the same spec? If so, do the different compressors mount to the engine the same and connect to the hoses the same? Please educate me.
Thanks, Cory1992 325i Cabrio
1988 320i Touring
2000 M5
1977 530i
BMWCCA
E30CCAComment
