E30 Fuse Box
  • Bene
    • Feb 2011
    • 358
    *bump for usefulness*
    • Dj Syco
      • 382
      Originally posted by fyfee
      is there a difference between the us spec and euro spec fuse boxes?
      my euro 323i has a 15 amp fuse for number 11 and also has a 15 amp fuse for number 15
      and my interior lights still work when i remove fuse 27...
      im so lost...
      bump for question needing to be answered. Friend got a 1984 320i and most are the same but every fuse is filled and K9 is fused as well.
      • vaportop
        • Sep 2011
        • 1
        Great......
        ___________________________________
        ผลบอล-sbobet-วิเคราะห์บอล-ทีเด็ดฟุตบอล-ทีเด็ด
        • techterr
          • Jun 2007
          • 91
          Originally posted by GunMetalGrey
          so the k9 slot is supposed to be empty on my e30 318i?
          Is your 318i a 91? because if it is, then fuse 9 is just power to the diagnostic plug. The later e30's have different wiring.
          this page has most of the wiring diagrams. And yes, each year is a little different....
          http://www.armchair.mb.ca/~dave/BMW/e30/
          take care.
          • SimplyDope
            • 1335
            Solid thread with good info. Thanks guys.
            • TobyB
              • 5228
              bump, because even if a circuit wasn't used, it was often populated with a fuse or relay.
              Example- 87 eta with no a/c still has the low and high speed fan relays installed....
              ...even though there was no electric fan!
              t
              • mcskibadee1
                • Feb 2012
                • 1379
                Which fuse is the fuel pump? I was thinking of pulling this fuse so the car can't be driven if someone tries to steal it. Is there a better one to pull?
                EDIT: found it, was on my phone and ddint see it.
                TRANSACTION FEEDBACK HERE
                FOR SALE ITEMS HERE
                • Link
                  • May 2012
                  • 834
                  Fuses guru's please look at this... http://www.r3vlimited.com/board/show...77#post3286577
                  View my build thread. http://www.r3vlimited.com/board/showthread.php?t=287724
                  • ohthejosh
                    • 4963
                    I had some spare time and thought this would help people read the diagram a bit more easily. Attached is the png as well.
                    SO MUCH MORE TO DO!!
                    IG: ohthejosh
                    LEGIT CHECK ME BRUH
                    BUYER FEEDBACK THREAD
                    • limp mode
                      • Jun 2012
                      • 117
                      def come in use thanks
                      • ohthejosh
                        • 4963
                        no prob
                        IG: ohthejosh
                        LEGIT CHECK ME BRUH
                        • Mastrcruse
                          • Sep 2005
                          • 5340
                          Anyone have any suggestions for continuously blowing fuse 19? The interior lights work, the aux fan works but when I touch the mirror switch it blows, dumbass PO had a cooked 20amp in there also. I think I have it down to the mirrors though as if I don't touch the switch the fuse doesnt blow. Could there be an easy fix to this? I'll be ripping out the dash so I should be able to check for scolded wiring when I remove it right?
                          • ucmego325
                            • Oct 2012
                            • 1
                            no spark
                            One[CODE]day I was driving my car as normal it parked it and it never started since I wasn't getting fuel or spark now I found put my o2 sensor words were ripped off the plug I fixed that and I started getting fuel again but no spark I just replaced the cap today in hopes of would fix the problem but still no spark is there anyone who could help me on this
                            • bradnic
                              • Jul 2012
                              • 3551
                              Hey I'll answer this 3 years later
                              K9 is used in Europe for rear fogs. If you look in the fuse block on a US car that position has no pins/wires to connect to.
                              Would be a cool retrofit for US..
                              HOWTOs:
                              DB vert plastic bumpers
                              OEM Keys
                              MTech1 docs
                              88 ix Lach/Card
                              91 ic Calypso 3.1
                              86 Cosmo 2.7
                              OEM+ or bust!
                              • Covelle
                                • Feb 2014
                                • 1
                                Originally posted by call me jack
                                i dont' think i can answer you question completely, but 28-30 means that fuse "28" is a 30 amp fuse, and by pulling it you will lose power to both your cigarette lighter, and your power antenna. hope this helps.
                                Where i can fix this cigarette lighter. need some information for my cigarette lighter. i cannot charge my device without this things. i think you will understand.
