DIY: Black Plastic Restoration
  • redlightpete
    • Mar 2012
    • 264
    #61
    I've had good results with black shoe polish also.
    • Regular6d
      • Dec 2014
      • 1
      #62
      Tri Sodium Phosphate (T.S.P.) also works well as a cleaner to get all of the waxes and mold release agent off I will post some pics when Im done with mine.
      • tomstin
        • Mar 2015
        • 563
        #63
        I had a Tacoma truck with black plastic wheel openings. The only thing I found that lasted more than a month or so was
        I have no affiliation with the product, just a happy customer.
        2004 525i Manual - 1985 325E Coupe Manual
        • TrentW
          • 2815
          #64
          Originally posted by jhaurimn
          Yes. It works great if the receptacles arent too far gone yet.
          Mine were pretty pink. Used some Zinno touch up paint and they look like new.
          • 86gt635
            • Jun 2012
            • 99
            #65
            How's this holding up OP?
            • jhaurimn
              • Nov 2012
              • 2224
              #66
              Car is under a cover right now hibernating, but last time I had the hood open, it still looked nice. I haven't reapplied any of this mixture to the airbox since I originally used it 2 years ago.
              Current:
              1989 325i
              1988 M3
              1987 325ic
              Past:
              2001 330ci
              2001 M3
              • squidmaster
                • Aug 2011
                • 2666
                #67
                mine are holding up well on the 190e. It's always in a garage fwiw
                • jhaurimn
                  • Nov 2012
                  • 2224
                  #68
                  Over two years later, havent reapplied the mixture since. Still looks pretty good. :) Probably could be reapplied again after this long.
                  Current:
                  1989 325i
                  1988 M3
                  1987 325ic
                  Past:
                  2001 330ci
                  2001 M3
                  • 86gt635
                    • Jun 2012
                    • 99
                    #69
                    Thanks for the update, looks like a great plastic treatment that will hold up for a while.
                    • rzerob
                      • Jun 2013
                      • 2315
                      #70
                      I did this with a window breaker button and it looked new. That was 3 months ago. It still looks new.
                      • noslolo
                        • May 2016
                        • 14
                        #71
                        I used the boiled linseed oil and paint thinner and it totally restored the plastic. the vents under the wipers were grey, darn near white and they now look brand new, one application and wipe it off. I did the side trim, front grille, all of the plastics in the engine bay, unreal.
                        • jhaurimn
                          • Nov 2012
                          • 2224
                          #72
                          Glad this helped you out! :D
                          Current:
                          1989 325i
                          1988 M3
                          1987 325ic
                          Past:
                          2001 330ci
                          2001 M3
                          • d_elson0
                            • Feb 2011
                            • 242
                            #73
                            what happens with a wash? does it smear onto paint or surrounding areas? just curious.
                            • jhaurimn
                              • Nov 2012
                              • 2224
                              #74
                              It doesnt really smear off during a wash because you remove it all when applying. The mixture reacts with plastic to make it look darker, not so much you leaving a thin layer of it on the plastic. If that makes sense
                              Current:
                              1989 325i
                              1988 M3
                              1987 325ic
                              Past:
                              2001 330ci
                              2001 M3
                              • jhaurimn
                                • Nov 2012
                                • 2224
                                #75
                                just bumping this for people who arent aware. It costs about $10 total at home depot, and youll never need to buy any more in your lifetime if you keep track of it. Works on any plastic (ideally plastic that hasnt been painted, and is its natural color)
                                Current:
                                1989 325i
                                1988 M3
                                1987 325ic
                                Past:
                                2001 330ci
                                2001 M3
