wow scab, cry becuse i wnna learn about e30's and cant find the exact anwsers im looking for....
Bumpers, bumpers, bumpers!
Has anyone ever tried this method to do a bumper tuck? This was in this DIY section, the very last entry.
15.2.2: Tucking in large front bumpers
(NOTE, this applies to the large 5mph silver bumpers on pre-89(?) E30s)
for anyone who has an E30, don't know if this applies to any others, and want
to shrink the front diving board, here's what to do. There is no need to
drill out the bumper shocks, nor replace them with 89-91 shocks which I was
about to do. Instead,
>remove bumper
>remove shocks
>loosen lock nut at the opposite end of shock about 1.5"s
>while holding shock body, turn the mount end clockwise and you'll magically
see the shock length decrease. You can keep turning until it bottoms.
>align the mount so that it will be vertical after the shock has been
replaced and tighten the lock nut.
> mount the shock, you will have to fiddle with the play in the shock mount
to the car in order to achieve the correct height from side to side so that
when the bumper is installed there is no gap along the top.
>actual time 20mins to do. This is a good time to check the turn signal
connections for corrosion, apply lithium grease here.
THIS WAS SO EASY AND THE APPEARANCE IS SUCH AN IMPROVEMENTComment
I don't think that there is a nut at the end of the shock....Has anyone ever tried this method to do a bumper tuck? This was in this DIY section, the very last entry.
>remove bumper
>remove shocks
1992 BMW 325iC
1978 Chevrolet Monte Carlo1965 Chevrolet Corvair Monza 140hpComment
Im pretty sure there are holes are already drilled.If I recall correctly the holes are used to mount the bumper surrounding on the '88. Just make sure you have the plastic bumper shocks. When we did my friend's '88 car there were gaps and I had to drive home and give him my spare plastic bumper shocks and gaps are gone.Anyone?
I know the shocks will bolt on but I need to install the side supports and since I have a 1988 I assume the body already has the plastic bumper support holes for mounting said supports...
Anyone who actually did the swap on a 88 comment? Alternatively have a friend with a 1990 325i coupe so definitely could make a template if need be.-Frank
1987 325is m50nv (schwarz)
1990 325is (sterling silber)(sold)
2001 525iComment
i have an 89 vert, and both front and rear plastic bumpers. However, i do not have the plastic part that goes under the rear bumper and hugs the exhaust. Is this the "unibody" you are referring to, if so, how do I obtain, and attach it to the plastic bumper I have?Comment
The part that is below the rear bumper of an original plastic bumpered car is not a plastic add-on. It is steel and, yes, part of the unibody. To do it right you would have to cut it off of a parts car and weld it onto the body of your car. It does not attach to the bumper.
ok question here, i have an 87 vert and i dont want to keep my stock db and im taking my kit off what would you guys suggest?
e24 e9 e30
IG: peterkaczynskiComment
plastic bumpers, you have shallow rear arches right?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.Comment
yup but with the plastic bumpers dont i have to do heavy mods to it?
and thanks for the quick response
e24 e9 e30
i night keep my rear skirt on that i have now but all im worried about the front, so the from plastic bumpers will just come on no problem?
e24 e9 e30
front plastics fit any e30 no problemYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
