Yep its the same but you should remove the bumper instead of running into a wall.
Bumpers, bumpers, bumpers!
How hard would it be to go from that bumper and airdam/cover...to this :
linkage
My current 4 door 325 has that some bumper/cover combo, and I hate it...I am the cars 5th owner..2owners back put it on...and did a shite job of it.The 9mm is a .45 set on stun.:mrgreen:Comment
Why the hell not? If you are a retard and hit the wall at 30MPH, you get what you deserve.
I have tucked bumpers on several cars, mine were just not gonna budge. I SLOWLY backed into a wall and mushed them in...why fuck with taking the bumper shocks out? Way too much hassle to do a 5 minute job.
LukeComment
Yeah, yours has the typical sag/shitty broken stock mounts.
Mine has that same bumper/airdam and I love it:
I pulled all of my shit apart, cleaned and painted everything, then re-aligned and tucked. Then I bolted the airdam directly to the bumper so no gap/sag.Comment
Is Jordos write up on late bumper swap still on the "tech" pages?
Why yes, here it is: http://www.r3vlimited.com/tech/bumper/bumper1.htm
Fronts are bolt on, rears are...um...a bit tougher.Comment
So I had the car (84 318i) on the lift today for an oil change and figured I'd pull out my printed copy of Josh Anderson's write up... My bumper has no holes in it at all, should I just take the bumper off using the 4 bolts that hold the bumper shocks to the car?1. Get on your back under the front bumper of the car. Look straight up, and there will be a hole on the underside of the metal part of the bumper about six inches in from each side. In these holes, are the 2 large bolts that hold the bumper on the car.Neal Mulcahy - 84 318i
LRRS/CCS #427 ECK-Racing 2009
Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Moon Performance | Motorcycles of Manchester | BostonMoto-Pirelli
I haven't looked at a DB bumper in awhile to remember how the shocks was bolted to the bumper. But i do remember that there is 6 bolts that hold the shocks onto the body. There is one in each side in the frame rail. The one above the muffler is harder to get to cause of the heat sheild.
1992 BMW 325iC
1978 Chevrolet Monte Carlo1965 Chevrolet Corvair Monza 140hpComment
