Shift Lever and Short Shifters
  • optimusp517
    • Oct 2005
    • 797
    #166
    wtf is the harmonic balancer? pics? hard to do?
    • Axxe
      • Aug 2004
      • 3355
      #167
      http://www.realoem.com/bmw/showparts...22&hg=26&fg=10
      Keep it slideways!!
      • optimusp517
        • Oct 2005
        • 797
        #168
        sweet! Now a question... Hmmmm how hard is it to remove it and wha'ts the process. Is there a DIY.
        • asubimmer
          • 6482
          #169
          318is's don't have harmonic balancers :twisted:
          ///AlpinweiĂŸ II 24v 91' 318is, AlpinweiĂŸ III 99' 323i, 04' Yamaha R6 SE for sale, 00' VW GTi, 83' El Camino BURNED, 01' P71sold, 92' Miatasold
          • Axxe
            • Aug 2004
            • 3355
            #170
            Remove 3 bolts, remove balancer, reinstall.
            Keep it slideways!!
            • optimusp517
              • Oct 2005
              • 797
              #171
              thanks guys, I really appreciate it!
              • Sean
                • 5793
                #172
                If you need help, PM me. I can give you a quick walk thru.
                Good luck! :)
                - Sean Hayes
                • moatilliatta
                  • 6121
                  #173
                  Originally posted by Sean
                  I'm running the Z4 3.0 lever in my car, and no bending was needed. Just remove that damn harmonic balancer.
                  ummm. the metal thing around the guibo?
                  i think thats not a harmonic balancer...
                  ________
                  Kawasaki EL250E
                  @Zakspeed_US
                  • Sean
                    • 5793
                    #174
                    Then what's the technical term? I kept thinking that's what it was called. Whatever it is - it's unneeded. My 88 doesn't have one. My dad's 89 does, though. Soon to be removed!
                    - Sean Hayes
                    • Jordan
                      • 12911
                      #175
                      It's a vibration dampener. Nothing more, nothing less.
                      It doesn't really seem to do a damn thing though.
                      BMW hasn't used them since ever, and alot of e30's didn't come with them to start with. Flex disc construction hasn't changed either.
                      https://mtechniqueabs.com/
                      • moatilliatta
                        • 6121
                        #176
                        yeah i took mine off. couldnt tell a diffrence. i can go faster thoiugh, dont know how much. took about a .8 of a pound off maybe. hahahha;)
                        i got the z4 3.0 shifter in last weekend with new guibo and center suportbearing and new bushings all around in the consold(sheet metal stamped one) and fresh fluid in tranie. i love the shifter. i laughed like the first couple days when i shifted. it was so funny how short it is. its like a big toggle swich. didnt even bend the selecter rod. i made a new back bushing, made the consold alot stiffer. anyone intersested i can find the partnumbers and show ya what i did.
                        ________
                        K1100RS
                        @Zakspeed_US
                        • jackyl
                          • Sep 2005
                          • 76
                          #177
                          Hi.
                          I bought a shortshift from understeer, and the shift lever that came in the package was with this part number:
                          25111434148
                          After checking realoem using this part number, the models that appeared are:
                          E34: Details on E34
                          E34 525ix SEDAN, Euro
                          E34 525ix TOURING, Euro
                          E46: Details on E46
                          E46 325xi SEDAN, U.S.
                          E46 325xi TOURING, U.S.
                          E46 330xi SEDAN, U.S.
                          E46 325xi SEDAN, Euro
                          E46 325xi TOURING, Euro
                          E46 330xd TOURING, Euro
                          E46 330xd SEDAN, Euro
                          E46 330xi TOURING, Euro
                          E46 330xi SEDAN, Euro
                          Z3: Details on Z3
                          Z3 Z3 1.9 ROADSTER, U.S.
                          Z3 Z3 2.5 ROADSTER, U.S.
                          Z3 Z3 2.5i ROADSTER, U.S.
                          Z3 Z3 1.8 ROADSTER, Euro
                          Z3 Z3 1.9 ROADSTER, Euro
                          Z3 Z3 2.0 ROADSTER, Euro
                          Z3 Z3 2.2i ROADSTER, Euro
                          I have a 320i, with a ZF gearbox.
                          It was a straight swap.
                          Just swap and play.
                          40 minutes took the job, with a factory jack, and one jackstand.
                          Easy job.
                          It´s very good.
                          I aprove the shortshift :)
                          • bebes2k
                            • May 2004
                            • 37
                            #178
                            My 91 318is came with one...soon to be removed thanks to the comments on this board!
                            • nickmp0wer
                              • 1427
                              #179
                              it seems like the best would be the m roadster bottom end with the x5, or maybe even higher, top. would it be possible to extend the top of the m roadster or other lever? i dunno if welding would be strong enough. or maybe take the top upper partion that the shifter mounts to and drill all the metal and rubber out of it and mount it ontop of the m lever
                              • moatilliatta
                                • 6121
                                #180
                                hahahha
                                ________
                                TS125 DUSTER
                                @Zakspeed_US
