OIL PAN Gasket Replacement Tips
have a part number for the good gasket? composite (cardboard like)The OEM cork gaskets leak eventually because they harden and the asymmetric expansion and contraction of the pan and block plus the vibration pulverizes them after a while...
The composite (cardboard like) ones only leak if installed with too much goop on them because of that same scrubbing action between the block and pan, the goop comes unstuck.
This tech information (SOP) is backed by 27 years of BMW oil pan gasket leaks (I've probably done like 300+(???) in that time) and I know what (and how long it took) to come back leaking again.
have a part number for the good gasket? composite (cardboard like)Last edited by johnwoo; 10-09-2008, 05:14 PM.
Thanks a bunch. That is what I needed. I will be doing on jackstands if I am to tackle this. Will see what I decide to do.Comment
Patrick - IG:niicknac
RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, baggedComment
a very small, very thin layer over the corners. If you use to much the gasket will push out and you will have another leak.
I ended up using straight RTV (loctite 5699 grey), no gasket. After building a couple SR20's, JDM mfg's kinda know how to build motors that don't leak.
Derek
DedericMSComment
This is what you need to cover both sides of gasket, block, and pan with. Let tack for 5 mins, install, and enjoy a clean driveway!
Turbo e30 M52. Built Motor, GT3582r
Watch my vids http://www.youtube.com/user/GrudgeRider156?feature=mhumComment
Certainly agree.I agree with the above.
I can't stand cork gaskets and I really can't stand RTV either. I have seen more oil leaks caused by rtv then not. In most case's rtv sealer is not applied correctly and this will almost always cause a leak sooner then if the gasket was simply applied correctly with no sealer.
I personally use a non-hardening liquid aviation gasket sealer/adhesive. I typically only use it on one side to secure the gasket to the mating surface.
RTV :down:
This information is backed by 20+yrs of general automotive repair experience.Comment
