OIL PAN Gasket Replacement Tips
 1988 Lachssilber E30 325i sedan.
 Factory fit-out: manual; SILBER LEDER; M SPORT SUSPENSION.
 Modifications so far: Miller MAF + 19# ECU; Ford 19# Design 3 injectors; IE adjustable FPR; KAMotors CF airbox; IM MTX-L; EBC Greenstuff.
 Retired - '83 Arctic Blue E28 528i powered by M30B32
 Is there any point to dropping the oil pump if it isn't needed to remove the pan eg are there components that are on a replacement schedule or recommended to clean or replace?sigpic
 wow, really? for the life of me I couldn't make that happen today. I was hoping to be able to raise the engine high enough and not having to remove the pump. but I still ended up removing it.
 Leo
 as long as you've filled it up with the proper amount you should be fine. There's still oil all up inside your motor unless you took a year to change your oil pan :)
 you might want to double check your fluid level after you're all done and ran it for a bitDas ist nicht nur nicht richtig, es ist nicht einmal falsch!Comment
 I was just defeated by the upper most torx bolt on the drivers side. It just won't budge and I was afraid I would have stripped it if I kept at it. I had to button up everything else all because of that one last fucking bolt! Arggg! :hitler:
 Its semi deep into the transmission tunnel... how are you guys getting at it?
 Thanks-Nick Originally posted by 87e30First of all: calm the fuck down; second of all; cool story bro. Originally posted by 87e30First of all: calm the fuck down; second of all; cool story bro.Comment
 hi there
 this is very good site
 you can find all stuffs here
 please click below:
 Top Ten Classified WebsiteComment
 Just another FYI on this tough job with pics..
  Bimmerforums is the preferred online BMW Forum and community for BMW owners. At Bimmerforums, you will find technical how-to information maintenance specifics audio advice wheel and tire combinations and model specific details not found anywhere else. Our professionals are here to help make sure you find the answers you need to your questions and our community is here to help other brainstorm ideas for the future. Bimmerforums is the preferred online BMW Forum and community for BMW owners. At Bimmerforums, you will find technical how-to information maintenance specifics audio advice wheel and tire combinations and model specific details not found anywhere else. Our professionals are here to help make sure you find the answers you need to your questions and our community is here to help other brainstorm ideas for the future.
 I have driven this for 1500 miles now and no leaks.. I would recommend the gasket maker over the gasket..Comment
 I used the paper MTC oil pan gasket and put Hi-Temp RTV (Red) on both sides coating it, been a couple weeks now and hasn't leaked. I only use hi-temp on my car for all gaskets because it has a bigger operating window than the rest. Bigger the temp range, the more likely it will work."I wanna see da boat movie"
 "I got a tree on my house"Comment
 Gasket help
 What I did was use small lengths of thread in every second hole on the pan to hold the gasket on while I was installing it and then after putting the bolts in the alternative holes pulled the thread out.Comment
 dude you responded to a year and more old post. I would hope he has his oil pan back on by now"I wanna see da boat movie"
