I disconnect the motor mounts (and usually replace them at this time).
then i use a bottle jack on the passenger engine mount arm. and then lift the engine ~3-4 inches. i have to bend the fan blades a little so clear the shroud.
then drop the pan, and never once have i needed to remove the oil pump.
if you are on a tight budget i would just use a jack and a small block of wood and do it the same way.
