Thanks, it worked. Auto light went off, but check engine remained... I'm gonna investigate that later, though :).
I have another question for you guys, so please bear with me on this one: got the OE wiring for the backup switch on the manual gearbox, but:
1) how do I get it into the interior compartment ? is it through the gearlever rubber sleeve ? If so, how, that thing has a very tiny hole, the wiring has connections on already - i don't think it's supposed to get them off, route it through the rubber sleeve and the re-fit the connections ?
This is the hole in the shifter sleeve: https://ibb.co/TLyNFnt
This is the wiring: https://ibb.co/6Nz6Ny1
If not, is there another hole I can route it through and haven't noticed yet ?
2) i've found a wiring with matching connector inside the dash (long white connector), is that the proper connection for the backup switch on the gearbox ?
