What 4x100 wheels will fit e30s?
  • Mr. Tasty
    • Jul 2011
    • 3421
    #151
    Originally posted by e30eu
    Thanks gtdragon980.
    Just one question more because if there is not the 8" wide wheels anymore left in stock, does the 16x9" ET20 (with 225/40 tyre) fit also in front? Or need the spacers then?
    you need at least +12mm offset for 16x9 to work in the front
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
    • tind
      • Feb 2014
      • 18
      #152
      What about these for a 90' 325ix?
      They are 14x6 - et 38.
      I'd probably need spacers all around, especially in the back, right?
      They look great imo, I love that look.
      These go for 75$ a piece in my country.
        • 34847
        #153
        If they are 4x100 and have the right centerbore they will fit. No spacers required.
        • F34R
          sLaughter
          • 12376
          #154
          This^ the Rota Slipstream are 16x8 et20 57.1 CB, they are designed for the BMW E30.
          Instagram: @BWeissLeather
          Current cars:
          ~ '87 325 M30B35 swap
          ~ '87 535
          ~ 01 540 Msport 6spd
          ~ '06 X5 4.8is
          • tind
            • Feb 2014
            • 18
            #155
            Great! Thanks. One more question, what is the deciding factor in brake caliper clearence? (If there's one).
            Enviado desde mi iPhone con Tapatalk
            • mitchlikesbikes
              • Dec 2013
              • 858
              #156
              offset plays a part, along with the overall design of the wheel. the flatter the back is, the less brake clearance there is.
              IG: @mitchlikesbikes
              • tind
                • Feb 2014
                • 18
                #157
                I know you said they will fit, but I just can't wait till tomorrow when I take the car to the tire shop and swap the wheels out. Can't wait to see my car finally having the wheels I always wanted.
                I just measured this, totally randomly.
                Still think they'll fit?
                Sorry about the pics, there's no much the Iphone 4s can do with that little light.
                Those are centimeters btw.
                ps: That's a really nice project you've got going on there.
                Edit: finally tried them on, BARELY cleared the calliper. I'm happy. Thanks guys
                • Cgannon
                  • Mar 2014
                  • 31
                  #158
                  looking to buy some esm-009 wheels, they are 15x8 with 10 offset. Would I need to get spacers? and what would be a good size tire?
                  • dickfitzwell
                    • May 2014
                    • 104
                    #159
                    spacers will push the wheel further from center and help you clear a caliper, atleast thats how i've always understood it. the lower the offset, the further out it sits. you could run stretch a 205 on there, if you really wanted to or were worried about fitment and alignment with the strut, but ive never been a fan of stretching, i prefer as much meat on the pavement as possible. i'd imagine with +10 on the wheels you might be able to run a 225 on these, with some fender rolling/pulling required in the rear for sure and probably in the front.. i'm new to the E30 but my last setup (MS3 with EVO X 18x8.5 +38 with 245/40) required a good pull and roll.. and still rubbed the rears, but i cleared the struts just fine. im sure one of the OG's will chime in so please correct me if im mistaken.. its all IIRC there.
                    - 91 318is - let the fun begin
                    WTB: Bilstein Sports/Koni Sports - IE3/HR Springs
                    • scuddyholly
                      • Aug 2014
                      • 116
                      #160
                      Hey guys, I'm new here- I just purchased an 89 325i and its been great picking up all this info about our cars. The very first cosmetic upgrade I absolutely have to do is getting new wheels. Mine are awful chrome 5 spoke wheels and I can't stress how ugly they make my car look, someone was smoking crack(is there a smiley for that?).
                      I've been looking for some stock wheels but haven't really found any yet. However I did find these wheels on craigslist http://images.craigslist.org/01010_2...C5_600x450.jpg
                      these are the specs i've found on the wheel
                      Sparco Pista
                      Offset: 35mm
                      Backspacing: 5.12"
                      Bolt Pattern: 5-100
                      Rec. Tire Size: 195/65-15
                      Weight: 16.6lbs.
                      Finish: Light Grey Painted
                      Construction: 1pc. Gravity Cast
                      I don't see anything about bore?
                      from what I gather the offset is pretty high?
                      will I have issues fitting these on my e30.
                      *these are miata spec wheels, and whatever wheel I settle on will be wrapped in Hankook 195 45 15 because thats what I already have-they are brand new.
                      pic on a 1 series
                      http://www.vividracing.com/catalog/w...co_pista_3.jpg
                      I'm on a $300 budget. A short term fix so I can spend money doing more important maintenance expenses. Thanks for the help..
                      //contact me for your marketing & design needs//
                      • JRKOUPE
                        • Dec 2004
                        • 3159
                        #161
                        scuddy...
                        bolt pattern say 5-100
                        thats 5 lug!
                        u asked about 4 x 100....so no go.
                        • scuddyholly
                          • Aug 2014
                          • 116
                          #162
                          sorry the one i was looking at is 4x100
                          "Sparco Pista Wheels 15x6.5 4x100 +37"
                          I guess all the specs are off then, i really can't find much on these wheels, I referenced the sparco website, tire rack, vivid and a miata wheel site, none were of much help.
                          I guess my question is, historically speaking, are miata wheels compatible with our bmw's?
                          miata:54.1 mm, 90-05'
                          E30: 57mm
                          • petrolhead
                            • 421
                            #163
                            E30: 57mm
                            I bought a set of Miata wheels, some special edition BBS RZs from 1997 I think. I had the center holes machined to E30's diameter of 57,1 mm. They're small but they weigh 4,7kg / corner. The machinist said they're as straight as any wheeel can be. Quality items I think.
                            -and they're for sale if anyones interested.
                            -Jarno
                            • pietro
                              • Sep 2014
                              • 56
                              #164
                              Arc-8 on stock height E30 cabrio? Anyone have pix?
                              Considering hyper black 17x8 ET25 Arc-8's for an '88 zinnoberot cabrio…
                              I've been lurking for weeks looking for photos, and haven't seen any with stock ride height and stock bumpers.
                              I'm wondering about the wheel gap, and whether the stock brake rotor will look too small through the spokes.
                              Any photos?
                              • Hussbuss
                                • Feb 2015
                                • 25
                                #165
                                Hopefully I read right and haven't seen this question asked..
                                16X9 with +15mm offset, with 10mm spacers all around. Would I need to Roll fenders or do you think I could live?
                                Schwartz '84 325e
