What 4x100 wheels will fit e30s?
  • rwh11385
    lance_entities
    • 18403
    #46
    Originally posted by sticksdaman
    the wheels are free so i figure why not give it a try
    good answer. yeah, give them a try with a moderate ride height and nonwide rubber.
    all else fails, sell them to a e21 owner
    • 2002maniac
      • 4260
      #47
      I'm 7.5" wide ET20 and no rubbing or fender touching, and my car is lowered about 2.5" in the front! 205 tires though. If you ran 16x8" with 225's I think it would fit with a 25-27mm offset.
      Where did you get your 16x7.5 rotas? I cant find them anywhere. Everyone has 16x7 only
      • Digitalwave
        is a poseur
        • 6284
        #48
        I was talking about my throwing stars.
        RISING EDGE
        • 2002maniac
          • 4260
          #49
          oops. I didnt realize this thread was so old.
          • shiraz
            • Jun 2006
            • 102
            #50
            I have these on my car...I didn't want spacers, they fit without. TSW Kyalami
            ...Sam :D
            • E30_pilot
              • Sep 2005
              • 1461
              #51
              Personally i dont like them. The lip isnt like that on the pic advertise.
              Here's how the look for our cars...pics are not of my car ;)
              -Frank
              1987 325is m50nv (schwarz)
              1990 325is (sterling silber)(sold)
              2001 525i
              • shiraz
                • Jun 2006
                • 102
                #52
                Mine are bigger than that and have the Hyper Black finish rather than whatever that is. The lip on mine is the same as in the picture I showed, which is the hyper black finish as well. They look quite a bit different and really alot better...if I can find my camera I will get pictures of them on my car.
                There is also another wheel made by TSW that fits these cars I believe...the Catalunya I think? This one...again in a hyper black finish.
                ...Sam :D
                • duuuurtymyk
                  • Apr 2006
                  • 111
                  #53
                  what about 15x8 zero offset? have you seen the sportmax's...super deep 3inch lip?
                  http://www.youtube.com/watch?v=JJ707dGNelg
                  ...and slide, and slide, and slide
                  • s52e368
                    • 539
                    #54
                    so im looking at some wheels
                    15x7
                    +38mm
                    ill need a 5-10 mm spacer correct ?
                    also is it safer to go with a stud kit or just longer bolts ?
                    • rwh11385
                      lance_entities
                      • 18403
                      #55
                      38 is wayyyy too high. no one makes 5 or 10mm hubcentric spacers, but the good thing is that a 15mm H&R puts you are ET23 which is good for a 7inch rim.
                      studs make the job a lot easier. try lining up a wheels and spacer then getting a bolt in. fuuunnnn. you'd need long ones since most medium ones can only fit a 12mm spacer.
                      too bad a set of 15mm spacers will cost you about $180-200
                      • Digitalwave
                        is a poseur
                        • 6284
                        #56
                        15x7
                        +38mm
                        15 or 20mm would be preferable. You could run 10mm though, it'd just sit inside the fenders a lot.
                        Studs are nice because its almost impossible to line the wheel + the spacer up to the bolt holes and stick the bolts through.
                        RISING EDGE
                        • rwh11385
                          lance_entities
                          • 18403
                          #57
                          VWVortex has nice selection of 4x100, 57.1 centerbore wheels. some offsets are high, but some are okay, just with narrow wheels.
                          i was frustrated trying to find euro weaves, so i looked otherwhere for other wheels
                          • s52e368
                            • 539
                            #58
                            well i found some vw k1's
                            so the centerbore would be the same. but the offset is 38
                            • rwh11385
                              lance_entities
                              • 18403
                              #59
                              and besides the "e-ballers" on clean slammed show cars and RS's, they are cheaper/poorer than us so you can get some sick deals.
                              15"x6.5" ET33 4x100 Factory corrado G60 wheels complete with mint center caps. Minimum curbrash, and a couple bends on the inside lip on 1 wheel but all hold air and drive fine. Located in toronto/brampton/hamilton area.
                              Asking $450 CDN for the wheels without tires. [$400 USD]
                              15x6.5 et33 is okay to run with 205s on E30s, same width as basketweaves, just you have a bigger wheels for better looks (and more $ tires, but much much easier to get good 205). I'd rock out those with undersized 205-50-15 cheap sticky tires and they would look bigger and a little better acceleration
                              http://forums.vwvortex.com/zerothread?id=2672756 - a set of 6 corrado rz wheels. if we buy both, we can both have a set of 5 direct fit BBS RZ's
                              there's a lot of others there too. i'm passing on the 6" ones, hoping for 7inchers, but definitely would rock 6.5" if I was wanting to run more 205-50-15
                              • s52e368
                                • 539
                                #60
                                Originally posted by rwh11385
                                http://forums.vwvortex.com/zeroforum?id=800
                                without spacers ?
