Charcoal Canister/Evap Valve
  • MattPro
    • Dec 2010
    • 502
    I've been searching around a lot to see what people do with their evap system after going megasquirt. I haven't found a general consensus anywhere, every thread I can find hasn't been very helpful.
    How do most of you handle your evap system? Just remove everything and vent to atmosphere? Plug the line going to the charcoal canister?
    Right now I just have the system in place but the evap valve not connected to anything. Wouldn't this be the same as just plugging the line into the charcoal canister?
    Thanks
    Thanks,
    Matt
    Check out my BMW Fault Code Index
    '89 Turbo M20 Zinno Cabrio (scrapped)
    '89 Zinno IX (sold)
    '91 Granit Turbo S52 Sedan (scrapped)
    '91 WIP (scrapped)
    '13 F10 Carbon Black 550iX MSport
    '91 iX Sedan
    • 34844
    if you have MS2 or MS3, hook it up and run it.
    there's nothing to gain by removing it.
    if you have MS1, you can just leave it alone.
    • Cyrix2k
      • 593
      Mine's vented to the atmosphere - I think I pulled the charcoal canister and just left the vent line open. It would be smart to shove a filter in the line.
      1997 540i/6 - stock
      1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
      1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
      • ColdAsLife
        • Mar 2013
        • 142
        I threw a breather on mine after I ditched the canister. Make sure the line is pointed upward so you can mitigate any risk of siphoning.
        • Northern
          I like cupcakes & sh!tboxes
          • 5282
          There was a thread about this where someone posted a realoem picture that just had a small tube extend from the breather tube on the tank down the front of the tank and end there, venting to atmosphere.
          I realized that my ix had the breather line missing off the car with a similar setup, so when I was looking to make room for the late coolant reservoir, I had no issues with tearing the charcoal cannister out and grinding the remnants of the studs down.
          Originally posted by priapism
          Originally posted by shameson
          • MattPro
            • Dec 2010
            • 502
            When would you trigger it to open? Just like overrun cut with high RPM/low TPS? I'm guessing the stock ECU handled it via vehicle speed sensor/RPM/tps on but I can't replicate that with MS2.
            Where do both of you have it mounted? Against the firewall?
            This is the only reason I'd want to get rid of it, for a little more space. Especially since I'm going turbo now if anything is not being used in the engine bay I'd like to get rid of it.
            And I wish I could find that thread, that seems interesting. I've some threads where people use a valve from an eta I think that has no electric trigger but I haven't seen a setup like that posted about anywhere.
            Thanks,
            Matt
            '89 Zinno IX (sold)
            '91 WIP (scrapped)
            '91 iX Sedan
            • Northern
              • 5282
              Found the thread:
              Post #7 has the realoem link that shows the piece I'm talking about (#15)
              • ColdAsLife
                • Mar 2013
                • 142
                I forget what i wedged the line against but its up on the firewall next to the brake fluid reservoir.
                • barbierij
                  • Sep 2012
                  • 1294
                  I'm going to use a mechanical one from an early 325, part #19 below. pn 11631707770
                  http://realoem.com/bmw/showparts.do?...07&hg=16&fg=10
                  I bought it from pelican mid september and received it last week so I havent had a chance to test it. Its pretty much just a check valve. They had to order it from Germany.
                  FS NY: two Audiobahn A235HC amps and audiobahn 1farad capacitor
                  Saab/GM tech2 programming
                  My for sale thread
                  1990 325iX for sale or part out
                  Did you buy something from me? Please leave feedback!
                  Originally posted by K20RI_211
                  And I have to ask if you make a hobby out of thread-bombing with retarded questions?
