M30 AFM swap vs. Performance Chip
  • DirtyTh3rty
    • May 2015
    • 101
    - M30 AFM + 19lb 4 pintle 4.6 v8 Ford injectors + Chip tuned for swap
    VS.
    - Miller W.A.R Chip or any good performance chip
    Ive done a bit of research on both but haven't got a lot on the M30 swap I'm really just interested in peoples opinions on either (pro's and con's and what not).
    I know the miller chip would be much more versatile but its a bit pricey.
    Given that I can get the M30 swap from a buddy for around $100 and the Miller W.A.R chip is around $400 I believe.
    Thanks in advance for any info and advice!
    88' BMW 325is - Daily
  • digger
    • Nov 2005
    • 6198
    i dont think the m30 afm gives any power on a stockish engine, atleast that was my experience. i would look to an option that allows a custom tune, this always is better than generic stuff
    • DirtyTh3rty
      • May 2015
      • 101
      My buddy had it on his 325i vert and said it woke it up a bit for sure I know it wouldn't be as much as the war chip he refers to is at the cheap mans MAF swap even though its not a maf its just getting more air and more gas. I am aware that it will run a bit rich but he says its really helps in the top end.
      This is stuff I've been told so I'm not saying this is all correct I'm just curious if anyone else has had experience with this setup.
        • 34844
        Don't bother. the M30 AFM has been a waste of time since day 1. get a performance chip.
        I would personally avoid the WAR chip and just get something from SSSquid or another reputable tune vendor. the WAR chip allows you to tune but the tunes it come with are typically bunk. Unless you're going to invest a lot of time (and money) on the dyno, you're better off getting one that's already tuned out of the box.
        • EatsHondas
          • Sep 2012
          • 404
          THANK YOU.
          /thread
          1989 325i Lachssilber Sedan
          5-Speed Swapped
          M30B35 Swapped
          MegaSquirt MS3X
          1987 325i Lachssilber Sedan
          260k OEM Automatic Daily Baby
          • DirtyTh3rty
            • May 2015
            • 101
            ok good to know. Thanks.
            Just referred to the war chip because it seemed to be pretty popular on here.
            Any other performance chip brands people recommend?
            • EatsHondas
              • Sep 2012
              • 404
              I really have to give props to Sssquid, a forum guy here. His chip for my 179 ECU was awesome. Noticeable difference in seat of the pants hauling.
              A genuine chip from Mark D'Sylva (MarkD) is also very cost effective.
              5-Speed Swapped
              M30B35 Swapped
              MegaSquirt MS3X
              • DirtyTh3rty
                • May 2015
                • 101
                What about a Jim Conforti chip?
                • ak-
                  • 12422
                  If you've got WAR Chip funds burning a hole in your pocket I would look into Megasquirt.
                  1991 325iS turbo
