Megasquirt not connecting
  • Chris Spiegl
    • Aug 2016
    • 155
    Hey y'all,
    Just got my PNP Megasquirt today from SSSquid.
    I am having a problem though.
    I cannot for the life of me get it connected to my computer. So far, I have tried two laptops (macbook pro and a windows 7). Two different usb to serial adapters (radioshack/gigaware and sabrent). I have the proper drivers installed. They both work properly with my LC-2 Wideband Programmer. I have tried every usb plug in on both laptops.
    On port scanner, I get "Com Port 3" with the results of "s". On the Com Port that the USB to serial is plugged into, I get no connection found.
    The megasquirt has a tune already loaded.
    I could not even get the car to start. It would keep cranking, but never started. It started once but stalled instantly.
    Thanks,
    Matt
    1987 325is 2.8L Stroker Turbo "Little Pickle aka The Green Turbo Sled"
  • Chris Spiegl
    • Aug 2016
    • 155
    Tried the built in ftdi mini usb to serial. Still no luck. Also tried reloading firmware and nothing.
    • varg
      Florida Turbo Man
      • May 2014
      • 3406
      Is the megasquirt getting 12V?
      IG @turbovarg
      '91 318is, M20 turbo
      • Chris Spiegl
        • Aug 2016
        • 155
        It is connected to my car, so I assume so. Whats the best way to test? (what pins etc)
        Thanks
        Edit: Just checked out your project thread and wow is that awesome! Havnt read it all yet though.
        Edit 2; Tonight I am going to try and jump the BL/TH?(i think thats what its called i forget off the top of my head... the 2 prong port next to the DB9) And see if that helps. If not, it will be sent back to Squid for more testing.
        • varg
          Florida Turbo Man
          • May 2014
          • 3406
          There should be some LEDs on the unit, one of which will light when it has power. Check pin 18 for 12v at all times, 27 for 12v when the key is on. A circuit in the ECU switches the main relay on in stock configuration which gives the ECU power for its higher current stuff via pin 37. Being a plug and play unit, no wiring mods should be necessary so it should function like the stock ECU and only need 12v on 27 to switch itself on and power the main relay.
          IG @turbovarg
          • Chris Spiegl
            • Aug 2016
            • 155
            Yikes. I was at ~9v. I grounded to GND under the BOOT. I am charging my battery right now and am upto about 11.9v.
            • Chris Spiegl
              • Aug 2016
              • 155
              Tested to 12.2volts but still no connection.
              • Chris Spiegl
                • Aug 2016
                • 155
                There is a video of me testing it.
                • varg
                  Florida Turbo Man
                  • May 2014
                  • 3406
                  Everything looks to be in order. Do you have 5V on the 5V rail?
                  IG @turbovarg
                  • nomansland92
                    • 1657
                    Welcome to the world of megasquirt and the reason I left it haha. Search Google to a port checker for your laptop, to see if your laptop is reading it or if it's something else.
                    IX being restored here
                    Ix turbo build here
                    • Chris Spiegl
                      • Aug 2016
                      • 155
                      Tried a port checker and nothing. The unit is in route back to sssquid for testing.
                      Thanks yall
                      • varg
                        Florida Turbo Man
                        • May 2014
                        • 3406
                        I've never had connection issues that weren't hardware related so excuse my limited helpfulness on this issue if all hardware is fine. Could be a port conflict or driver issue, but I don't see how if your adapter worked with something else.
                        IG @turbovarg
                        • Chris Spiegl
                          • Aug 2016
                          • 155
                          Megasquirt hardware is not my strong suit. I also have very limited time on my hands. The package it was delivered in was destroyed so that could be the cause. It should be delivered today for more testing. Thanks
