SSSquidBoard for Motronic 1.1 1.3 Now Available (E30, E28, E34, etc)
  • squidmaster
    • Aug 2011
    • 2666
    The SSSquidBoard is a great piece of hardware for those of you looking to run two separate tunes in your Motronic 1.1 or 1.3 ECU for situations like track days, smog testing, valet/shop security, fuel economy, octane switching, etc! What it does is allows you to install two chips within one single ECU and choose between which one you want to run.
    Install a performance tune in one slot for track days with higher octane, and the stock chip in the other slot for lower octane and daily driving; or get a valet mode tune in one slot to limit RPM and speed, and your race car tune in the other because race car. Quickly switch to a stock tune when putting your car through smog testing and never have to worry about anything looking out of place, then switch easily back to your performance tune as soon as you leave the shop with a crisp new “PASSED” sticker on your windshield. Never have to worry about a gas station having the correct octane on a road trip by easily switching back and forth between tunes with the flick of a switch. Heading to the dyno and need to compare two different setups? Not a problem!
    Simply run the cable from your ECU to any mounting position of your choice, and hide the switch easily in your cabin with the included incognito black waterproof molded cover.
    Unlike other products, you aren't limited to just my tunes, you can put whatever you want in there! Have a Conforti or Dinan or whatever other brand you want to use instead of anything from me? It doesn't discriminate!
    for many Motronic 1.3 ECUs (M1.3 DME) including, but not limited to the following ECU models.
    153
    173
    380
    381
    524
    525
    526
    While this daughterboard may fit into other ECUs, it has only been tested on the above models.
    All r3v members get an extra 20% discount on the SSSquidBoard until the end of March 2017! Use coupon code "SSSB20"!
    PURCHASE AT THE LINK BELOW
    http://sssquid.com/v2/shop/bmw/sssquidboard173/
  • squidmaster
    • Aug 2011
    • 2666
    Just tested to fit and work in Motronic 1.1 model number 153 DME!
    • squidmaster
      • Aug 2011
      • 2666
      Bump!
      • downforce22
        • Aug 2009
        • 3193
        Always great to see new products for the e30 community!
        • Northern
          I like cupcakes & sh!tboxes
          • 5284
          Website still says "or those of you looking to run two separate tunes in your E34 or E36 413 DME" which I assume is a typo.
          Originally posted by priapism
          Originally posted by shameson
          • squidmaster
            • Aug 2011
            • 2666
            No it doesn't (thanks for pointing that out)
