Does 13 button OBC & Check Panel functionality work with MSPNP2?
  • Raja_Mongkut
    • Aug 2012
    • 75
    Hey there, was planning to drop some money on a MSPNP2, but before that I would like to check if it works with the 13 button OBC and Check Panel?
    I tried using the search button but it was inconclusive.
  • Digitalwave
    is a poseur
    • 6300
    Check panel is independent. I think a couple functions of the OBC might rely on the ECU, and those would no longer work.
    RISING EDGE
    • Raja_Mongkut
      • Aug 2012
      • 75
      Thanks for confirming that!
      • varg
        Florida Turbo Man
        • May 2014
        • 3437
        All fuel related OBC functions depend on the Motronic ECU's "present fuel rate output" which is lost when converting to megasquirt. It is technically possible to retain these functions and the MPG gauge by analyzing the output signal of a stock ECU and making an intermediate module that converts the MS injector output into a signal which is equivalent to the ECU fuel rate output and I believe it has been done, but it's not trivial.
        IG @turbovarg
        '91 318is, M20 turbo
