where's whodwho, and DIYPNPB55 is discontinued....
  • bradnic
    • Jul 2012
    • 3554
    Finally getting around to a stroker build for my coupe and MM install for Callie the vert... and I've emailed and PM'd whodwho to pick up a couple of his MS2 ECUs but no response..
    I really want to keep the factory harness intact if possible.. don't have enough time as it is without getting stuck building a custom engine harness.
    Does anyone have any suggestions? No issue building a kit, just really wanted whodwho's MS2 in a motronic case setup :-(
    HOWTOs:
    DB vert plastic bumpers
    OEM Keys
    MTech1 docs
    88 ix Lach/Card
    91 ic Calypso 3.1
    86 Cosmo 2.7
    OEM+ or bust!
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4516
    WhodWho is building a batch right now- I sent him a "case" a few weeks ago.
    If you PM him on here and let him know you sent him an email he'll probably respond, at least that's what I did!
    He did mention he was overloaded with MS2 requests and is still working his day job.
    SSSquid can also build you a nice MS2 unit in a case he 3d prints for stock location. He also has a true MAF conversion that can also do SD and a few other things- may be worth shooting him an email as well.
    • bradnic
      • Jul 2012
      • 3554
      AWDBOB thanks.. I get the impression Keith has been buried with backlog for quite a while now - years. Just really hope to hear back from him. Honestly I really want an original Motronic case and the aftermarket ECU's I/O to work with the stock harness, minimal changes - as close to PNP as I can get it.
      ForcedFirebird dropped youa note as well
      HOWTOs:
      OEM Keys
      MTech1 docs
      88 ix Lach/Card
      91 ic Calypso 3.1
      86 Cosmo 2.7
      OEM+ or bust!
      • whodwho
        • Jun 2008
        • 1547
        Hey Brad, I had replied to your email yesterday(it was a different email address), I can forward it again to the one in your PM 8^)
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
        • bradnic
          • Jul 2012
          • 3554
          JUST GOT IT. Thanks Keith!
          HOWTOs:
          OEM Keys
          MTech1 docs
          88 ix Lach/Card
          91 ic Calypso 3.1
          86 Cosmo 2.7
          OEM+ or bust!
          • McGyver
            • 4636
            I've been working on detailed MS2 v3.0 build instructions, if you wanna follow that route.
            https://www.r3vlimited.com/board/for...ild-and-wiring
            • 318aye
              • Jun 2010
              • 895
              Keith is the very definition of an essential service.
              • CrazyJew89
                • Oct 2009
                • 347
                Is someone able to PM me whodwho's e-mail address. I have the feeling that is going to be the best way for me to get a hold of him about a MS PnP system.
                '87 5-speed 325is
                The best $750 I ever spent!
                Are you in Michigan?
                Do you want to know where all the E30's are?
                Try checking out the Michigan E30 Map
                • CrazyJew89
                  • Oct 2009
                  • 347
                  Got it. Thanks
                  '87 5-speed 325is
                  • sk8
                    • Dec 2015
                    • 20
                    You could always go the Speeduino route if you want to keep the stock ecu case and are looking for a plug and play solution.
                    • McLove30
                      • Jul 2020
                      • 3
                      Is someone able to PM me @whodwho's e-mail address. I have the feeling that is going to be the best way for me to get a hold of him about a MS PnP system.
