Turbo on standard Motronic
to answer your question about finding 30# injectors: bosch mustang injectors will fit and you can find them pretty cheap because mustang guys are always going bigger. i just bought 8 30# orange tops for $150. so hopefully you can find someone who will ship internationally
im doing a low budget turbo build myself on my '89 325ix. i have a low cr stroker engine w/ stock internals, 30# injectors, metric blue head studs, stage 3 clutch, gt-35 rep. turbo (till i can get something precision) and 3" exhaust. but i still need to get the WAR chip. im not nearly done and im at already about $3000 deep including the engine.
might have some build pics up soon
i wish you luck!
If you wrote the xdf that we have been using since 09 then yes we are :)
We just got a JimStim from DIYautotune and plan on going further into the code. Thanks for opening up the doors for the DIY-er on the Motronic stuff, so many people have been keeping the a guarded secret and for no reason, really. The GM OBDI stuff isn't like that at all, and becuse it's so shared the ECU's now can read 3bar MAP sensors, have wideband capabilities, can do electronic boost control etc. If the BMW crowd had done the same thing, perhaps not everyone would be jumping on the MegaSquirt bandwagon so quickly.
I tried your MAF conversion, but not sure how you were doing it, when we tried it, the MAF would max at 8psi and ~4krpm under load.Comment
Motronic can do what M20 can take. Porsche 911 has the same motronic system with flap AFM and makes 300hp. With a use of M30 AFM on the suction side of the turbo I think motronic can be tuned for some serious boost.
As for other vendor's expensive motronic tunes, maybe you can back me up. They don't do much when they tune, they bump the timing up, bump the fuel maps just a bit, raise rev limit and thats all, they don't dig into code as I did.Comment
