m20 supercharger kit on its way :18901motorsports
  • Syncro325is
    • 574
    #91
    Hey guys, the setup has the blower before the throttle body so that you can choose the mount a front mount intercooler. The recirculation valve makes this possible. It's not terribly loud like a blowoff valve but you can hear it at wot. The TB being before the roots blower essentially creates an enormous intake manifold if you are using a front mounted intercooler because there will be vacuum in the charge pipes, which was very ineffective due to the couplers sucking in on themselves. Believe me, I've run through a few variations of this kit, and this setup by far is the best for drivability and power. I'm at work currently and will respond tonight in more detail when I'm at a computer.
    • MaxBell
      • 1391
      #92
      Interesting. I'm interested in this, but would you detail for me how your bypass valve works?
      REMEMBER: Be safe and have fun is Rule Number 1.
      The Epic Unbuild of Clint Eastwood
      • Ether-D
        • Sep 2011
        • 2838
        #93
        How's it goin?
        Originally posted by Andy.B
        I was born on 3/25…
        • newman8r
          • Feb 2014
          • 683
          #94
          I'm interested. I can do without a/c, I am a fan of Power steering though....
          • RickSloan
            • 2401
            #95
            We just bought a 3D Printer. The snow is melting. Stay tuned.
            Need Illustration or Design work? www.robbiebyerly.com
            • Q5Quint
              • Jan 2005
              • 725
              #96
              Nothing wrong with throttle after charger- just need to make sure your bypass is big enough.
              What type of 3d printer did you fellers go with?
              • Ether-D
                • Sep 2011
                • 2838
                #97
                So, from the diagram, why is TB after SC better for high boost? I can't figure it out.
                I was born on 3/25…
                • Syncro325is
                  • 574
                  #98
                  Printrbot plus v2, Its great so far! getting all the settings calibrated and upgraded the printer nozzels for better print resolution. Currently printing some fan funnel upgrades and then by the end of the night I hope to be printing out some prototypes of the throttle positioning adapters. The materials and the possibilities are amazing. Currently working with bicompostable Polylactic acid filaments and getting some pretty snazzy and strong products, infact I've been rethinking the intake pipes to the charger since I've been playing with this new machine ;)
                  Great visual aid by the way! ;)
                  • Q5Quint
                    • Jan 2005
                    • 725
                    #99
                    I think it is from a jaguar website so take it with some salt, but it is a nice picture.
                    I had a turbo blowing onto my throttle body before so I don't know why a supercharger that literally turns itself off on vacume or boost would be any worse?
                    The built in actuator opens on vacume correct? So when you close a throttle body infront of the compressor, the resulting vacume opens the bypass so it stops pumping?
                    As long as that actuator is sourcing vac/boost from the intake manifold it would seem like this would still happen normally, and still cut the compressor off when you close the throttle. A BOV/bypass in front of the tb is double insurence to keep pressure in the charge pipes below 15psi at all times.
                    • george graves
                      • 20003
                      #100
                      I like that there are dueling m20 supercharger threads going on. May the best set up win!!! (or both - each one might have a thing of their own)
                      Originally posted by Matt-B
                      • Syncro325is
                        • 574
                        #101
                        Originally I had used the built in bypass system but I had noticed huge pressure spikes from the pressure in the pipes post charger. Currently there is a seperate bypass valve close to the throttle plate. It routes back into the charger via the stock bypass location.
                        In other news the new lc2 wideband is installed and communicating correctly with the megasquirt setup, so we have an appointment with the dyno this saturday. We will be running the lower boost pulley that we will are offering with the kit first and then swapping over to the pulley that I run on the car normally. Will report back with some dyno numbers so long as everything goes well!
                        • VintageBimmer
                          • Jan 2014
                          • 137
                          #102
                          any speculation on when this kit will be available?
                          -1991 m50/s50 318i :up:
                          -1989 325ix (sold)
                          • frontin40
                            • Jun 2012
                            • 74
                            #103
                            I'm in for one if you get ac to work with it. Living in Arizona makes it mandatory.
                            87 325e
                            • VintageBimmer
                              • Jan 2014
                              • 137
                              #104
                              id rather have ac than ps
                              -1989 325ix (sold)
                              • Syncro325is
                                • 574
                                #105
                                Well we got on the dyno the other day. I ran the car without the charger and then with the charger on low boost and made about a 20 percent power gain at the wheels on a fresh head with a block that has 230k miles on it. A little more refining and I'd say we have a ready product! We are waiting on a dual extrusion head for our 3d printer so we can start testing the model I designed for the intake pipe to the supercharger. Printing will let us get precise fitment while allowing us to keep the interior of the pipe smooth.
