M10 knowledge.
  • E30_Pare
    • 7801
    #121
    Originally posted by jeffnhiscars
    If the ICV restricts air to lower your idle (ie the "penny trick") what would a hose do ?
    Switch to night shift ?;)
    I see your point lol. Plugs all around. Il report back with results
    DREWLIENTE
    1$ PShops PM me
    • E30_Pare
      • 7801
      #122
      Went to lowes got some rubber plugs. Fit quite nice. Plugged the intake boot & manifold got my idle down to around 1000-1200rpm.
      Did a valve adjustment this morning before I started working on it. Did a .07 on the intake side pulls consistently till redline.
      Cut down on hesitation quite a bit, but still hesitates when it's hot out.
      DREWLIENTE
      1$ PShops PM me
      • E30_Pare
        • 7801
        #123
        I think the hesitation may be an ignition issue. My cap has chunks missing from the contacts. Going to try new wires plugs cap & rotor
        DREWLIENTE
        1$ PShops PM me
        • jeffnhiscars
          • Jun 2011
          • 6011
          #124
          DING DING ! DING !!
          I recently dropped all mine form .010 to .008 and it made a world of difference. What did you set the exhausts to ?
          hey. When its hot out, I hesitate too.
          Alice the Time Capsule
          • Hey_You
            • Nov 2009
            • 963
            #125
            The specs I got for valve adjustments is .008 for intake and .010 for exhaust. Seems to work just fine for me. Mixed with a little timing advance from the dizzy, pulls good enough for a decent daily
            85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
            • E30_Pare
              • 7801
              #126
              My exhaust is at .010. Had intake set at .010 before I did .007.
              What r the three relays in the small black box next to the airbox? The tall relay in the center clicks like crazy when hot. Think it might by a fuel pump relay
              DREWLIENTE
              1$ PShops PM me
              • E30_Pare
                • 7801
                #127
                Doesn't look so bad right?
                DREWLIENTE
                1$ PShops PM me
                • Hey_You
                  • Nov 2009
                  • 963
                  #128
                  If that relay is always clicking, sounds like you may have a ground issue. Double check the ground on your intake manifold. Mine was loose and I had all sorts of issues related to my fuel pumps and relays after I put my engine back together. And yes, those 3 relays are Fuel Pump, Master Relay, and I don't know what the little 3rd one is
                  • thebutterson
                    • 463
                    #129
                    This
                    • E30_Pare
                      • 7801
                      #130
                      All right il check it tomorrow. Anyways finally got to do some work on the e30 after almost a year of siting.
                      DREWLIENTE
                      1$ PShops PM me
                      • jeffnhiscars
                        • Jun 2011
                        • 6011
                        #131
                        I understand the speckled paint, but speckled clear coat on the windshield..thats too much !!
                        • E30_Pare
                          • 7801
                          #132
                          U know how hard it was to wash lol. Washed it 3 times & still has a layer of dirt. Clay bar coming soon
                          DREWLIENTE
                          1$ PShops PM me
                          • E30_Pare
                            • 7801
                            #133
                            Ok so checked intake ground next to fuel rail where icv used to be. It's snug. Even cleaned both grounds & intake surface with sand paper for a better connection.
                            Weird thing though was that both pump relays were clicking like crazy when car was off & grounds dissconnected. When I reconnected the ground relays started clicking even faster.
                            I cleaned the contacts & connectors for relays also & seemed to work for the moment, but still unsure because relays click sporadically spontaneously.
                            I took a vid il post up later when I get home
                            DREWLIENTE
                            1$ PShops PM me
                            • E30_Pare
                              • 7801
                              #134
                              Disregard my brown ass hands
                              DREWLIENTE
                              1$ PShops PM me
                              • Jaxx_
                                • Dec 2009
                                • 1880
                                #135
                                Why don't you actually start troubleshooting it? No one can do so from a computer. Pull the relay cover off at least and see which relays are clicking. When you find that find your issue with the ground.
