M10 knowledge.
  • E30_Pare
    • 7801
    #106
    That's what I thought as well. He said something was done to it. I have no idea still w8ing to hear back. Either way I need a better dizzy.
    DREWLIENTE
    1$ PShops PM me
    • Jaxx_
      • Dec 2009
      • 1880
      #107
      what he probably meant was the electronic conversion from points.... but 318i dizzys are already electronic... so not really sure what he could be talking about.
      • TobyB
        • 5243
        #108
        I don't think that dizzy is anything special
        what, the pertronix wires don't make it look specially snazzy?
        t
        • E30_Pare
          • 7801
          #109
          I thought pertronic was pointless for e30 m10s cause the OEM system was as good or better??
          DREWLIENTE
          1$ PShops PM me
          • Smelser
            • Feb 2011
            • 633
            #110
            E30, your right, the Dizzys are "pointless" wich is why they are electronic.
            Now, if you excuse me, I need to go set the points on my John Deere, it wont start and I havent got the Petronix Pointless distributor for it yet.
            Damn points
            sigpic1984 318i Total conversion to a DIRT race car.
            Check out our build on facebook @ www.facebook.com/brewstermotorsports
            • E30_Pare
              • 7801
              #111
              I found M10 poly mounts from Revshift. They offer a soft/street version & hard/race. Going to bite the bullet & street the race mounts.
              DREWLIENTE
              1$ PShops PM me
              • E30_Pare
                • 7801
                #112
                3k idle any ideas? For sure the icv & module r at fault. Using the penny method at the moment to tame it down to around 1100rpm.
                When I unplug the connector from icv idle jumps a bit. Does that mean only module is at fault.
                Small vacuum line on intake boot broke off any effect on idle?
                Haven't checked the tps but I have an almost new replacement.
                Wont hold idle on cold start. Replaced the inline pump & helped a bit. Turns out the in tank pump was only supplying fuel.
                Haven't checked the thermostat yet, but my fan doesn't kick on. Will replace the relays to see if fan kicks on.
                Radiator has a crack in it so won't hold fluid. Found a replacement & need to flush system.
                Adjusted timing with a light from the view window on the trans. & the little sensor ahead of the air box is broken.
                Anything else i need to check?
                DREWLIENTE
                1$ PShops PM me
                • jeffnhiscars
                  • Jun 2011
                  • 6010
                  #113
                  Originally posted by E30_Pare
                  3k idle any ideas?
                  Lots of intake leaks & a questionable ICV
                  No. The ICV can still be sticking & remember its default position is wide open
                  Ummm...YES & YES again
                  Since you say relays I assume you mean the aux fan. It should only kick in when the AC is on or when it hits the set point of your temp sensor. Likeliest culprit is the fan resister. Swap out the 15A fuse #4 for a 30A then jump the resistor to confirm your fan works
                  fluid will help :-)
                  Do a smoke test and eliminate vacuum leaks
                  Alice the Time Capsule
                  • E30_Pare
                    • 7801
                    #114
                    Well got the idle down to 2k.
                    Checked my Tstat temp sensor looks good no crazy build up. I have a feeling my tstat is stick open. Haven't been able to boil it yet. Car is siting 40miles from my house so need to limp it home.
                    Going to wrap up the intake boot with duct tape & see if I can eliminate some leaks.
                    Anyway to test icv & module? I've already cleaned icv to no avail
                    DREWLIENTE
                    1$ PShops PM me
                    • ruizl300
                      • Apr 2012
                      • 67
                      #115
                      Why dont you do a ICV delete? Helped my crazy idle problems.
                      • Hey_You
                        • Nov 2009
                        • 963
                        #116
                        I removed my ICV and solved my hunting idle. I recommend you do the same. Also, I do not run an auxiliary fan and do not have any temperature problems. Even when stuck in LA traffic for 2 hours on a 100 degree day, it kept constant (Did get warm, but I kept my eye on it, and it never went above 3/4) Under most circumstances, the mechanical fan will suffice.
                        85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
                        • E30_Pare
                          • 7801
                          #117
                          I'm planing to keep my AC. Just moved out to the desert & would really like to keep it. As far as i know I need the icv & aux fan to work if I have any chance of functioning AC
                          DREWLIENTE
                          1$ PShops PM me
                          • jeffnhiscars
                            • Jun 2011
                            • 6010
                            #118
                            The only effect the ICV has on AC is to raise the idle to compensate for the compressor load. You can do this manually if you deleted it.
                            • E30_Pare
                              • 7801
                              #119
                              That's what I thought. So when I delete do I just run a hose to the intake manifold? Or do I plug the manifold & loop the other two hoses.
                              I check the tps it's clicking. Still haven't done the thermostat. Im quite sure I have vacuum leaks.
                              When its hot out car starts to misfire & lose power. At night it's completely fine. What does this mean?
                              DREWLIENTE
                              1$ PShops PM me
                              • jeffnhiscars
                                • Jun 2011
                                • 6010
                                #120
                                If the ICV restricts air to lower your idle (ie the "penny trick") what would a hose do ?
                                Switch to night shift ?;)
