Is anyone using an aftermarket Sanden a/c compressor in the m10? Just looking for some thoughts and maybe an idea on how to mount it to the block. I know most aftermarket kits are long gone!
Sanden a/c compressor in 318i m10?
Tags: None
I had a sanden 508 on my M10 and you are on point about the mounting bracket being NLA. That's your challengeSeat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
Alice the Time Capsule
87 Zinno Cabrio barn find 98k and still smells like a barn. Build thread http://www.r3vlimited.com/board/show...20#post3455220 -
Check with bluntech.
Not sure if the 2002 setup would work?
Sent from my iPhone using TapatalkComment
I know this is an old thread, but I wanted to post this just in case it helps anyone. I have a 1985 318i with AC converted to R134a. I am running a Sanden SD5H14 compressor with an AC Solutions fully isolated M10 bracket with bushings. The Sanden compressor and AC Solutions bracket work great together. Good luck!
Designed with originality in mind, this kit is used to fit the Sanden 508 or 709 Compressor (SD5H14) (SD7H15) to the S14 and M10 engine block using a fully isolated (bushed) design similar to that of the factory E30 M3 assembly. Professionally engineered, designed, and manufactured in California, this has been fully FEComment
https://www.acsolutions.co/products/...0&_ss=e&_v=1.0
I haven't been on here in sometime; thank you for the info. I installed this factory updated m10/s14 a/c bracket, it doesn't use any bushings so there is more vibrations from it. Here is the link to it:
https://www.ecstuning.com/b-genuine-...t/82399404494/Comment
