885 head valves and rockers
  • RousseauGTR
    • Aug 2022
    • 1
    I had issues on my m20b25 on my 89 325 convertible. Also it was automatic, so I bought a 1988 super eta 325 for the manual swap.
    After some readings I choosed to go the 2.7i stroker with the super eta base and the vert head. During the process I discovered that the problem with the vert engine was cause by the timing strap wich broke. After opening the head pretty much all the exhaust valves are scrap and a rocker is broken.
    The question is, are the rockers and valves the same on the m20b25 and the m20b27 super eta.
    Thanks
  • It's Soda Not Pop
    • Jan 2022
    • 877
    Thanks
    The valves and rockers are the same as long as it's a true super eta. But the springs and cam are different.
    88' Seta 2.7i Zinno
    https://www.r3vlimited.com/board/for...430-my-88-seta
    • It's Soda Not Pop
      • Jan 2022
      • 877
      These guys offer some upgrades if you are a "while I'm in there" guy. You buy a complete head are all the bits for internals if you like. From mild to wild.
      88' Seta 2.7i Zinno
      • ForcedFirebird
        • Feb 2007
        • 8300
        The seta used an 885 head, just like the b25. The b25 has a better cam and added inner valve springs. The seta manifold is crap, use the b25 stuff.
        john@m20guru.com
        Links:
        • reelizmpro
          • 9558
          Yes, the rockers and valves are the same between 325i and 88 325 Super ETA.
          88 M3 - LACHSSILBER
          89 M3 - ALPINEWEISS II
