Okay to run original ETA pistons with 885 (i) head if I'm going to turbo?
  • jc1000
    • Aug 2022
    • 60
    Originally posted by digger
    I second the keep it simple. Put the m20b25 head, topend gubbins and induction and boost it. Let sleeping dogs in the bottom end lie provided the comp test and leak down don’t show its munted. The 40whp gain FF refers to is along way from an apples to apples comparison. If this was a NA engine it would be a totally different approach.
    also if building a stroker bottom end for boost a 2.7 with factory rods and slugs is not the best choice and savings are not enough to justify these budget items IMO
    Thanks digger, this is very helpful. So if I am going to boost, you think I should just leave the 2.7 bottom end as is and add on the i top. Any idea on a ballpark HP going this route?
    Still want to hear any and all opinions as I make these decisions. I am still new to all of this. Thanks.
    • digger
      • Nov 2005
      • 6194
      NA is 140-150whp so rough rule of thumb is 1bar boost will be 280-300whp and so on depends on turbo and what part of efficiency map you run etc. others will be able to recommend it’s not my thing
      I might be wrong but DBO YouTube channel may have done a “stroker” turbo might have been slight different and based on SETA
      • ForcedFirebird
        • Feb 2007
        • 8300
        No, my suggestion isn't the "easiest", but it's not far.
        In my experience, you will see anywhere from mid 250's to about 500whp depending on the turbo you select. A 58-60mm turbo will get you 300whp at 13psi, on a normal b25, personally done several of those (Turbonetics Super 60, or Garrett t04e etc). A 6266 at 19-ish psi will net you about 500whp (did one for a local, he made 518 @ 19psi). An HX35 at 15psi will get you about 340whp. Granted, these will all be VERY different spool rates. The 6266 won't see full boost until about 5000rpm, whereas a 56mm will be closer to 3500rpm.
        If you want an idea of what yours will make, browse these forum builds. A lot of them are using flat pistons, and you will also get a feel for the turbo you would like.
        john@m20guru.com
        Links:
        • hasa
          • May 2013
          • 307
          I'd add that the art is to make it streetable, waking up early but not fading out too early. Turbo selection is crucial here.
          I see forums full of turbo shit that spools up @5000, puts out nice power but must hit limiter somewhere @6500. That kind of car is slower in traffic light races than average diesel cab. Lots of noise and wheelspin, but not much performance.
          • jc1000
            • Aug 2022
            • 60
            Thanks, ForcedFirebird. Can you clarify what your suggestion would be? To use the B25 pistons if possible, right? What is the most straightforward way to do that with the ETA block? Maybe shaving the block is part of that suggestion, but I don't understand how.
            • jc1000
              • Aug 2022
              • 60
              Thanks hasa. I am new to the turbo scene. Is there a "tried and true" option I can go with for the M20 setup? One that most agree is a solid choice?
              • jc1000
                • Aug 2022
                • 60
                By using the b25 pistons, eta rods/crank and shaving the block 2mm puts you around 180whp. So, that in itself should show you the importance of piston shape in the m20. The 2.7i (885 head on flat pistons) and budget stroker both displace the same, but the 2.7i will have about 8.3:1 compression, the budget stroker is closer to 9.3:1. By using the proper shaped pistons, that 1:1 compression bump gives you ~40whp more.
                ForcedFirebird I am considering doing this. If I can source some pistons, is it as simple as asking the machine shop to take 2mm off the block? Anything else I would need to do?
                • jc1000
                  • Aug 2022
                  • 60
                  Originally posted by mikey.antonakakis
                  I’m currently using the eta pistons with 885 head. I live at high altitude so the deficiencies are more noticeable, especially with turbo. So I’m going to build a not-budget stroker, lol. And I wish I had used the “i” pistons from the start.
                  That said, I 100% agree with hasa in this case, and although I want a different setup now, that’s exactly why I went with that in the first place. I had to draw the line in project budget and scope to focus on other aspects, like engine management.
                  Hi there, following up about a year later lol. You said you wish you had used the i pistons. Is it as simple as swapping out the e ones for the i ones? Or is there more to it than that?
                  mikey.antonakakis
