High idle once warm
  • BrownHausE30
    • Jul 2025
    • 6
    High idle once warm
    First time posting, long time reader!
    I have a 325i convertible 1986, owned it for 10 years and love it when it runs right
    over the last year I have been chasing a high idle issue, when the car warms and I’ve driven it for more then 30 minutes the idle will sit at 1500rpm
    the list of things replaced it’s as follows
    -new idle control valve
    -rebuilt TB with new seals
    -checked and calibrated AFM
    -ECU tested by injectronics (Australian ecu repairer)
    -New rocker cover with gasket and D seals
    -Fuel system rebuild after tank went rusty (new pumps, injectors, reg, filter and lines as well as tank)
    -New intake boot
    -New intake manifold gaskets
    -Converted TPS from 6 to 3 pin and installed new TPS
    I’ve also tried blocking off the booster line when the issue occurs with no change
    any suggestions are welcome, I am starting to think I have a faulty wiring harness as I’m at a loss to what it might be
    (just quickly, I own a workshop and specialise in VAG cars, this old girl is testing me big time)
  • tomstin
    • Mar 2015
    • 570
    A few thoughts, there is a harness connector under the intake manifold that tends to corrode over time. Unplug that and make sure all the pins are clean. Next, I have more experience with the E model, but check the various temperature sensors are reporting resistance back to the ECU correctly. There is a good write up for the E model, not sure on the I models.
    2004 525i Manual - 1985 325E Coupe Manual
    • BrownHausE30
      • Jul 2025
      • 6
      Thanks tomstin, I’ll look for that connector
      I have also replaced the temp sensor but thank you for the suggestion
      • 82eye
        • Jan 2009
        • 2108
        have you done a smoke test on a warm engine?
        • It's Soda Not Pop
          • Jan 2022
          • 877
          The new ICV is it Bosch (OEM) or knock off brand? If so they can cause issues. I have ran into this problem.
          88' Seta 2.7i Zinno
          https://www.r3vlimited.com/board/for...430-my-88-seta
          • BrownHausE30
            • Jul 2025
            • 6
            I did previously hence the new rocker cover gasket and D seals
            • BrownHausE30
              • Jul 2025
              • 6
              it was a Bosch part, sure I purchased it through FCP
              • It's Soda Not Pop
                • Jan 2022
                • 877
                88' Seta 2.7i Zinno
                • BrownHausE30
                  • Jul 2025
                  • 6
                  Update
                  found my ICV connector pins to be spreading when warm causing the erratic idle, squeezed the pins back together and stabilised idle significantly​
                  • BrownHausE30
                    • Jul 2025
                    • 6
                    Just went on a extended road test, issue resolved
                    might look into getting a new wiring harness made up
                    • packratbimmer
                      • Dec 2009
                      • 1335
                      Can you hear an audible click at the throttle switch when returning the throttle to rest? The 325i really enjoys having the throttle plate and switch adjusted properly.
