Well, I Am Going To Add Triple Webers To My 3.0L M20…
  • digger
    • Nov 2005
    • 6194
    Originally posted by E30-TourZing
    Thank you for the details Digger. I have reached out to Rama, and they do not have anything to do with carbs any longer. I am about to pull the trigger on some 45's Webers. My options are between a 5 progression hole vs 3. The cost is about $1000 more for the 5-hole. The seller/tuner (based in England) says the 3-hole setup would be fine since I have a SOHC. I can understand how a 5-hole would work more smoothly, but it would require more tuning etc. I dont mind spending more, but only if it makes sense. Any advice between the two?
    Does anyone know is Andrew (SkiFree) is still around? He seems to have all the answers I may need, but he hasnt been active on any of his accounts in 5-years. I recall him being a regular on this form in the past.
    Sorry, i cant provide any informed comments about progression holes
    try contacting Adams Autosport https://www.instagram.com/adamsautosport/?hl=en if you haven't already. Someone else might have other contacts
    • TobyB
      • 5288
      You'll be able to make either 40's or 45s work, and the difference will be mostly in mixture control.
      It might not even be all that hard to get either to work in similar circumstances.
      However, this has been my experience:
      I bought a 2L race car that had 40s with 32mm chokes per the rules of the class.
      It ran fine, made 150 solid horsepowers, and pulled to a 7000 redline, falling off starting about 6700.
      Long runner Canon manifolds.
      The rules changed. Now 45s were ok, and chokes were unrestricted.
      I went to a 34mm choke, and then a 36mm choke, and the redline went to 7500 with absolutely no falloff.
      Idle SHOULD have gone to shit with 36, but the car metered well from 2000, and pulled strongly
      (as in, solid a/f ratios) from there. Horsepowers were never measured, but lap times said they went up significantly.
      Doing the straight maths, probably to 180.
      I then got me some Spanish 45's, and lap times went to hell. After some EGT gauges, it turned out that one
      jet well of one Weber was machined too deep, and there was no real fix for it.
      Then I got me another Weber, and stuck 36mm chokes in, and after some more tuning, got back to my
      40 lap times. Went to 38 mm chokes. Didn't go noticeably faster, and tuning wasn't any more difficult.
      The jet combinations made more SENSE than they did on the 40s (larger mains, smaller air correctors)
      but the lap times stayed roughly the same. This was on the same type Canon manifold, but opened
      up for 45s. All the other variables factored in, the 45's weren't good for more than tenths of a second
      on the straights. Which in a race car is all well and good, but on a street car, silly.
      So here's my limited opinion: with a smaller cylinder M20, I'd stick with 40s on the street. Then the throttle
      plate will open further at just-off-idle, and the progressions will have a chance to work. If you start
      on a 34mm choke, tuning will be easy, and your carburetted top end will probably be over 7000, based on what
      I experienced with the 2l engine. You WILL be giving up just a titch- but unless you're planning on
      tuning at Bonneville and running tracks with long straights, you're REALLY not going to notice all that much.
      What you get in return is better mixture control at idle.
      Is it a big deal?
      Prolly not. So if 45's make you happier, do that.
      As to progression drillings, I've always been frustrated by the Weber method. If I was to spend real time
      on street development, that's where I'd start filling and drilling....
      For spark, it's not going to matter. I used a 6MSDal for the limiter with a rusty Accel coil
      and never had any blowout problems.
      If you already have the 'squirts, I'd use it for its tunability. There's both power and driveability in a good,
      load- sensing spark timing system.
      I found DBilas' opinions to be... opinions. And their products to be... heavy. They certainly go fast, though.
      t
      opinions are like Miatas...
      • E30-TourZing
        • Feb 2017
        • 147
        Is it a big deal?
        t
        Thank you for the time spent explaining these details. I have a few specific questions.
        It seems running 40mm carbs but having 36mm chokes can cause some drivability issues around town. At least I have been told this. I get the impression 30mm-34mm is ideal for 40's but bigger than that 45's make more sense. Do you think doing an initial setup with a 36mm choke/45mm would make my 3.0L hard to tune?
        Are you referring to a stock m20 as a 'smaller cylinder M20?'
        My local weber supplier (redline) says that the FJAS carbs are better quality than the Spanish Webers. They are also half the price. Thats quite an impressive claim. Especially when the Weber forms I have recently signed on seem to say the same thing. Anyone here have anything to add about the FJAS carbs?
        I am looking pretty seriously into the iBooster setup. I am doing some deeper dives with this, but it seems like a better compromise considering the vacuum isn't the best with carbs, and it allows even more space. My daily has an iBooster setup and it works quite well. Any thoughts on this conversion for my touring? It would be nice to setup the canbus, but I feel a bit out of my comfort zone sorting the electronics out. (perhaps I am over-thinking the difficulty)
        Thank you all again for your help!
        • TobyB
          • 5288
          Yes, anecdotally it makes sense, as a 36mm choke only provides a 4mm restriction on the 40mm bore.
          In THEORY that's not very much 'depression' for metering.
          I really do think that 40's with a 34mm choke will be enough if you're not planning on holding the throttle
          open for minutes at 7000+ rpm. But then, 45's ARE bigger...
          I had expected the race car to change character when I put 36mm chokes in, but it really didn't seem to affect
          anything very much, other than top end airflow. Metering did change, but it wasn't more than incremental.
          Keeping in mind, of course, that while a race car spends very little time at 'puttering' speeds, I didn't notice
          anything unusual in driving out to pregrid...
          A 36mm choke in a 45 would provide a very good venturi, and give good metering. Again, the real challenge
          will be the tiny throttle angles it'll need to putter down to pregrid at 35mph, and it won' uncover the progression
          holes very much, if at all...
          yup, an M10b20 has a 500ml cylinder, and an M20b25 has a 416ml cylinder, so each throat on an M20 will be
          drawing 83% of what an M10 will at the same rpm...
          If FJAS is one of the suppliers from China, I've heard similar- that some Cast in China carbs are very good for what they are.
          If you can get a return guarantee, it would probably be worth trying them. When I was having issues,
          I put pyrometers in the headers, and for $50 a runner, they were really useful, in combination with a wideband
          in the collector, at telling me how close to balanced the carbs were.
          When I had a booster on the racecar, with a pretty aggressive cam, I never had vacuum issues.
          Closed throttle is closed throttle, and the booster just needs to be evacuated between braking events.
          That said, getting rid of the booster is nice, since it's always in the way.
          t
          • digger
            • Nov 2005
            • 6194
            pretty sure we are talking about a 3L 6 cylinder
            • E30-TourZing
              • Feb 2017
              • 147
              t
              Thank you Toby and Digger for the input!
              So my actual CC's are 2926. So 488cc per cylinder. If I am gathering this correctly, you are saying with the 40's, the progression holes will be uncovered and thus assist better than if I run 45's and a 34mm choke? (which is at its min)
              I feel inclined to give the FJAS a try based on the reports coming back to me. Its just a bit unusual for me to order 'replica' parts, but smoother tuning is key, and it sounds the FJAS have more consistency. But man, its hard to say. So many differing opinions in this subject. I wasn't expecting this! Haha
              Which booster did you use on your race car? Was your setup in an E30? Also, did you run vacuum from the carbs or the manifold?
              • digger
                • Nov 2005
                • 6194
                dont trust anything you read on forums
                • E30-TourZing
                  • Feb 2017
                  • 147
                  Fair play! I am pretty much secure on the DCOE’s.
                  The next thing I can’t get past is the brake booster. An iBooster seems like a logical choice, but I am concerned that the feel wont be as familiar as ‘normal’ cars do. I wont be able to run the Canbus from what I can sort out, so it will be in a sort of emergency mode with basic hookups. I am not sure how modulated this will feel. I daily drive a 2025 vehicle and it feels like I would hope my E30 would feel. I am just not confident I can expect the same.
                  Any input on what boosters have worked for others running DCOE’s would be super appreciated. I suspect I can pull enough vacuum off an evenly pulled manifold to support a booster.
                  In other news, I got a line on some Racing Dynamics headers custom made by a guy in Ontario. I am going to pull the trigger. Would anyone else like a set? They aren’t ‘cheap’ but seemingly very well made and a once-in-a-life-time header. (At least that’s what I tell my wife)
                  • TobyB
                    • 5288
                    ESPECIALLY if I've posted it.
                    Sorry, I missed that it was a 3l engine. In which case, it's very much a wash.
                    40's are at the top end of their flow, and will be a limit if you REALLY hold it wide open after 6500,
                    whereas the 45s might be a bit harder to tune just off idle.
                    Yes, the progression drillings come into play based solely on throttle angle, which will have to be smaller with the 45's at low sppeds.
                    If there was a non- destructive way to modify them, it'd be a lot easier to tune street cars. I've only really thoroughly
                    worked on them with an M10 race car, so I'm only an expert on digger's internet.
                    As to boosters, not much help as the E30 race car has a stock- type setup per the rules,
                    and I've left the stock booster.
                    On the M10 race car, I eliminated the booster, but it makes for a pretty hard push for a cold- pad stop,
                    and that's also true on the other non- boosted disc- brake cars I have some experience with
                    (volvo 122, datsun roadster). So no help here. the ibooster looks cool- but if it wants car data,
                    that's a bunch of work.
                    t
                    • E30-TourZing
                      • Feb 2017
                      • 147
                      t
                      Thank you for the reply Toby. You were able to fit DCOE's with a stock booster in an E30 before? Did you just run really short inlet tubes?
                      • TobyB
                        • 5288
                        Nope, sorry, haven't tried that. My DCOE experience is with a 2002. Which certainly DID have interference issues...
                        t
                        has 2 racecars, one a mostly- stock E30, another a very not- stock 2002
                        • E30-TourZing
                          • Feb 2017
                          • 147
                          Hello Gang! Well, I have some progress to mentioned. I ended up buying some new Japanese made SK47 DCOE carbs. I got them ultrasonic cleaned as well. So far the quality looks amazing. My touring is next on my list of projects, and I have a number of questions to ask you guys.
                          Just off an eye, I am concerned I will find a brake booster which will work. I will be getting my manifold soon, but I have done some loose math and its going to need to be a different setup than what I have considered. Thinking of going manual brakes. This kit looks good -https://srs-concept.com/product/e30-brake-booster-delete-kit-tandem/
                          Any thoughts on this setup? Ideally I would like to keep the brake booster. I love the way the car feels right now.
                          Another consideration is fuel pump related. I only need 2.5-3 psi, so its clearly much to high of pressure with the stock pump. My question is, with a high quality regulator, would I not be able to just run the stock pump as long as it had a return? Will it cause me more grief than anything else?
                          Thank you all for your input! I will be doing more frequent updates on the build process starting this month
                          • E30-TourZing
                            • Feb 2017
                            • 147
                            Here are the new triples
                            • digger
                              • Nov 2005
                              • 6194
                              you need to look at the manifold and how it fits in relation to booster my guess is you will need to delete or relocate the booster
                              i would look at this Lee was probably first to bring to e30 market
                              The design of this Dual MC Brake Booster Delete kit started in 2013 at the same time as the notorious e30 single MC booster delete kit, and distribution started in 2015. Pedal ratio can be adjusted to 6-to-1 or 7:-to-1 The balance bar (Tilton 72-250) allows easy adjustment of front-to-rear braking
                              • E30-TourZing
                                • Feb 2017
                                • 147
                                Hello guys. I finally have an update. Dbilas has finally sent over the manifold and it works like a treat. I do need to shave off the thermostat housing to accommodate the front carb, but that was previously mentioned.
                                Big issue is my booster. I need 8cm of space on that side for even these trumpets to function. My hope is to add longer ones later as I am worried about the torque level with my current setup.
                                Anyone have any input outside of manual brakes? An iBooster can work, but I am worried about the feel. Anyone have personal experience here?
