Performance Chips
  • Alkasquawlik
    • 4557
    I have the stock injectors too and just bought the 91 level chip that coincided with that, so I personally have no reference to it. I have a friend who switched his injectors though and he said it made a huge difference. Like I said, its through word of mouth. Hopefully someone who has experienced it first hand will chime in and can tell you.
    SC*AR
    Originally posted by JamesE30
    And with a car looking like yours I imagine the balance shall tip in the favor of insult, like a big fat fucking retarded fucking black girl on a see-saw, opposite... a dwarf.
    • red325
      • 961
      Originally posted by redbmw
      I run a stock m20. should I keep the 14#injectors or would I gain more performance if I switch to the 19#injectors?
      I was wondering the same thing. I think I might go ahead and get the 19 pound injectors because to do any significant engine upgrades you need to be running larger injectors.
      • digger
        • Nov 2005
        • 6216
        There is no advantage in using the 19lb ones, the stock injectors can handle the majority of bolt ons that get done.......
        • red325
          • 961
          OK well would the 19 pound injectors and a chip make a very significant gain in performance or would I be just as well running stock injectors and a chip.
          • 325ix
            • Aug 2009
            • 7783
            is a mark d 91 octane chip a direct plug and play for a 88 325ix?
            • urbancynic
              • Dec 2008
              • 384
              if you get the chip for that model, then yes. its simple. search for install write ups and follow the instructions. its really easy and takes less than 30 minutes.
