2 timing belt jobs in 1 weekend, or Use RTV sealant on the water pump gasket
  • LateFan
    • May 2013
    • 4436
    Originally posted by funcrew
    Coolant system RTV - just a shmear.
    Block side, WP side, or both sides of gasket? (noob question - about to do a WP)
    Thanks -
    • Cletonius
      • 2809
      I've never had a plain paper gasket leak if the surfaces are cleaned appropriately. No sealant is required.
      - Josh
      1990 325is
      Need a shift boot?
      Looking to buy shift boot frames, PM if you have one to sell
      Here's what happens when you let the internet pick your license plate
      • coldweatherblue
        • 393
        also have never had a problem with WP gasket leaking. I always use a new gasket and clean the surfaces like any gasket and haven't had a leak (knock on wood).
        • downforce22
          • Aug 2009
          • 3193
          i didnt take out the radiator and the gasket wasn't lined up when I put the water pump on so it ripped. I needed the car the next day so I used rtv to seal the gasket to the pump and then torqued it and it has worked great. The block is still clean and the gasket has a good seal with no leaks.
          • jeffnhiscars
            • Jun 2011
            • 6011
            IMHO the only time RTV has a use on an e30 is for a short term temporary emergency repairs. I use Permatex #2 (non hardening) for anything water jacket related and have not had a leak in decades...but thats just me :-)
            Alice the Time Capsule
            • Kozworth
              • May 2011
              • 1339
              I used copper gasket spray to hold the gasket to the wpump, and never had any leaks. When i used rtv, it made a mess and leaked.
              • cabriodster87
                • Jan 2011
                • 1042
                A little on the WP side will do, just to hold the gasket in place.
                Reich und Roll!
