Educated Hp guess help.
    • 34839
    #46
    yeah, he could bump up the fuel pressure to 3.5 bar and keep his stock injectors.
    • E30Pedia
      • 140
      #47
      hmm, i know a really good local tuner. He does Gentani cars. But it would be about 200$ for a tune. I guess i can save money for the tune instead on the 19lbs injectors.
        • 34839
        #48
        $200 for a tune is cheap, if he's actually any good. dyno time here costs $100 an hour, plus $50 setup. that's without a tuner to guide you.
        • E30Pedia
          • 140
          #49
          We know the guy, he is my brothers friend. Plus we are also good friends with the Gintani shop owner. i can prolly get my car on the dyno for less than 50bux.
          ^^ thats him
          • E30Pedia
            • 140
            #50
            Mega Squirt or WAR chip?
              • 34839
              #51
              there are advantages and disadvantages of both
              war chip-
              pros:
              easy to set up
              relatively cheap
              MAF conversion is easy
              you only have to worry about timing/fuel maps
              cons:
              stuck with Motronic 1.3 hardware limitations (single coil, batch injection, no boost support, smaller injectors)
              no real datalogging
              no support outside of miller
              closed source - if miller disappears, you're stuck.
              megasquirt-
              pros:
              control over everything
              highly customizeable
              not stuck with limitations of the stock hardware (cop/sequential is possible now/soon)
              wide ranging support - used everywhere
              MAP sensor (no intake restrictions)
              open source - constantly being updated
              cons:
              harder to set up (steep learning curve)
              you have to tune everything (that means learning)
              costs a bit more
              improper installations can lead to issues (bad wiring/soldering)
              the amount of options/possibilities is confusing to new users
              if you want something tomorrow, get the WAR chip. if you don't mind spending 6 months reading and learning before you dive in (to avoid getting lost because you don't understand how EFI works), then get megasquirt.
              • E30Pedia
                • 140
                #52
                yea, i am leaning towards WAR chip. the tuner said working with the mega squrit is a headache.
                  • 34839
                  #53
                  it is if you don't understand it. especially if your tuner doesn't like it, then get the WAR chip.
                  • E30Pedia
                    • 140
                    #54
                    Hey nando thanks for all the help man
                    Seriously appriciate it:up:
                    • LowR3V'in
                      • 4209
                      #55
                      It's all pesonal prefrence.
                      You like to have full control of the ecu and see exactly what's
                      going on? :)
                      Cool thing about MS is that tons of M20/M30 guys
                      are using it so you got... TONS of support for settings.
                      Back when I first used it, I got a really really rough msq from somebody.
                      Drove to work 20minutes after plugging everything up. Cold starts where terrible, no ICV, VE was a mess.
                      Now people have got everything down. Basically get a good msq and you'll be in the ballpark.
                      Now there's VE anylize live, so it autotunes while you drive.
                      Probably get a clean factory like VE in 30minutes.
                      Not to mention many many awesome features and a datalogger.
                      You'll probably get about the same hp +/- with a chip vs ms if you're stock (ish).
                      :hitler:
