m52 crank/ b27 rods/ b25 piston build, ready to start.
  • kilgojr
    • 33
    #31
    Originally posted by rvaughnp
    Well... like i said... if the purchuser of the parts starts a thread of the build maybe he can continue it.
    Okay, well, after looking through this thread and seeing that there was some interest in people following this build I guess I can continue the build thread for my car with RV's parts.
    I purchased the parts and got them in just last week. RV did a great job of packaging everything for me and the care he took for shipping me the crankshaft was outstanding. I am more then pleased with the parts and can not wait to get my car back together and running with help from Robert.
    I'll post up some background on my car and the past year in just a bit, but for now I have some work to finish up.
    John K.
    AL region SCCA RE
    Autocross CoChair
    1989 sedan 3__i
    basically stock
    • kilgojr
      • 33
      #32
      A little background
      I bought my E30 in 2008, from a guy in Ft Walton Beach, FL.
      This is what it looked like on the way back to Alabama...
      Shortly after having it, I did some suspension mods, and just started doing maintenance items that had long been ignored.
      After a year of autocrossing and learning about the local scene, my brother and I started making plans for what we wanted to do. We decided that autocrossing was fun, but we really wanted to do Time Trials and Hillclimbs. This is the point when my brother decided he wanted his own E30. So.....
      I decided at this point, that it was time for more power. So.....
      Megasquirt, T3/4, and some money thrown in for good measure I had this
      At the beginning of 2011 our cars were looking good, and performing good. One turbo e30, one 2.5L NA e30.
Name:	t9r at tgpr 2.jpg
      this is when it all started going downhill. I blew my motor the second day of competition license school at TGPR. So, new plan....get another motor, put turbo on it, and good to go, right? Wrong, blew the second motor in June of 2011. So, third motor, back to NA. We hoped to have everything back together in time to compete with both cars at the Crow Mountain Hillclimb in Hollywood, AL in October. Well, we competed, but with only one car.
      It was tons of fun, as you can see here. But at this point I was getting very frustrated with my car not running. So that is when it was decided to start looking at really doing a NA motor, and doing it right. A complete rebuild, striped down to bare block, bare head, spec everything, and build a high revving motor. That is where I now stand.
      So the plan is this.......
      2.8 stroker motor (obviously built with the parts that started this thread in Robert's possession)
      VAC competition valve springs
      new cam (at this point still being decided upon)
      headers
      side exit exhaust
      and for the car.....well, continue it on its diet, work on aerodynamics, and make even more room for the 275 hoosiers on the rear.
      John K.
      AL region SCCA RE
      Autocross CoChair
      1989 sedan 3__i
      basically stock
      • ROLLingKING
        • Apr 2011
        • 1169
        #33
        damn..sry to hear about all the blown motors.lol glad to see u havnt given up tho. to many ppl call it quits after a blow and its sad to see
        what are u doing for the diet?? im looking for lighter replacement doors, trunk and hood if possible. or are u just taking interior stuff out?
        m20 is plenty. im simply a drifter.
        build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
          • 34844
          #34
          I've said it before, and I'll say it again.
          if you're even going to bother building an M20 stroker - and doing it right - do a 3.1. if you aren't doing a junyard-parts-bin build, the cost difference between a 2.8 and a 3.1 is essentialy nil.
          • digger
            • Nov 2005
            • 6197
            #35
            i still think there is merit in the 2.7 or 2.8 option if it is done with some thought, but IMO it is when you start doing custom pistons that might as well go all out
            • sofargone561
              • Jan 2011
              • 250
              #36
              more info on this 3.1 stroker? i saw a 3.0 i was very interested in. how well do they hold up to boost?
              my build thread:
              http://www.r3vlimited.com/board/showthread.php?t=231612
              • kilgojr
                • 33
                #37
                Its been a bit, but here are some updates.
                I got my block back from the machine shop. I had it hot-tanked, honed, and all the specs checked. It came back perfect. A coat of paint, and its ready for assembly.
                Crank was put in dry, and all the main bearings were torqued and plastigauged to check tolerances. A few of the bearings were moved around to get the clearances as even as possible across the main bearing journals.
Name:	crank torquing.JPG
                Once that was done, the same thing was done with the Pistons and Rod journals. A few bearings were moved around after clearances were initially check to have even tolerances across the face of the crankshaft.
Name:	crank completed.JPG
                After the bottom end was in place, and all the seals put back in, we started putting the crank scraper and oil pump in place.
Name:	close crank scraper.JPG
                So that completed the bottom end.
Name:	bottom end complete.JPG
                John K.
                AL region SCCA RE
                Autocross CoChair
                1989 sedan 3__i
                basically stock
                • kilgojr
                  • 33
                  #38
                  So here's a few more pictures that didn't upload on my second post last night.
                  drivers seat and interior cage shot, with all the battery wiring being redone, its a mess right now
                  this is the engine bay, that is housing all the peripherals right now....soon it will house the motor
                  here is another shot of the crankscraper installed
Name:	side crank scraper.JPG
                  John K.
                  AL region SCCA RE
                  Autocross CoChair
                  1989 sedan 3__i
                  basically stock
                  • loofee
                    • 9
                    #39
                    Just to update this thread: the bottom end and tranny is in, and hopfully with the new cam here we should have the head in the car this Sunday. stay tuned. C
                    • team9
                      • 82
                      #40
                      The engine is back together and has started. A new 285/285 CatCams cam was put in. Bought it from VAC Motorsports and it's a drop in unit.
                      And last but not least, the engine did start. What a relief!!!
                      We had only a few small hiccups when putting everything back together. The thermostat housing has a small leak, so we need a new one of those. Other stuff just includes small things and then double checking everything. The tuning and running the car will be a very happy day.
                      Mark K
                      1989 BMW 325i
                      SCCA SEDIV TT Street Mod Champion 2011
