Direct swap larger throttle body M20?
  • Dagamus(NM)
    • 620
    Not likely, but I may still have pics of one that happened to a while back on one of computers.
    Anyways, I am going to with an adapter just because I want to see how the throttle response is with one of them.
    Gun control means using both hands
    Sex, Drugs, Rock 'n roll. Pick two.
    • digger
      • Nov 2005
      • 6188
      Originally posted by Lunner
      What is this now?
      Its a M20 throttle body bored out to accept an M30 butterfly works out to be +3-4mm or so.
      • digger
        • Nov 2005
        • 6188
        BBTB have been done for donkeys years on the M20 never heard of problem unless you start going more than 65mm. Establish that a 63-64mm butterfly is too small before you start adding in more complexity than you might need.
        • rvaughnp
          • 136
          That sound like the way to go.:p
          I will look up a supplier for the plate off the M30. Or just a salvage yard.
          Then you would keep the vac lines and etc. as stock. Cool.
          Thanks Digger.
            • 34844
            yeah, it really is the simplest and most direct way to do it. I haven't put mine in yet, need to have my intake manifold tanked and blasted, I already cleaned up the TB inlet and matched it to the new TB and gasket matched the outlets.
            • rvaughnp
              • 136
              Just put in an "order" for a M30 butterfly valve on different boards. Hopefully I can come up with one. Being I will be getting the Miller MAF, why not open it up as much as possible?
              I looked around on multiple sites, no one seems to sell it individually.
              I'll keep looking.
              • rvaughnp
                • 136
                Does anyone have specs on the plate? I wonder if i could get a local water jet company to cut one?
                  • 34844
                  I know it's 65mm.. don't know the thickness.
                  • rvaughnp
                    • 136
                    Thanks Nando,
                    I will pull the one out of the M20, it should be the same thickness and measure it. then try to make some phones calls this week.
                    • Luis325
                      • 3847
                      Let me know! im interested in this as well...
                      What cars can you find the bigger tb?
                      1986 "C2 2.7 Alpina" Sedan
                      1987 325ic Black Vert
                      • whodwho
                        • Jun 2008
                        • 1547
                        The problem with making one is that the edges are angled. It looks like the ones from an M50 are the same as a M30. I have an M50 one next to me with a M20 TB apart waiting to be machined for it.
                        Couple pics to see the diff on the two
                        My M20 Frankenbuild(s)
                        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                        • rvaughnp
                          • 136
                          OK, the M20 butterfly plate is:
                          Round - roughly 60mm (it is really an egg shape more than a circle by about .25mm, just fyi)
                          Thick - 1.95mm
                          The throttle bore is more of a venturi shape. Meaning the inlet and outlet are roughly the same size but the center at the rod where the plate attaches is narrower.
                          The inlet is roughly 63.5mm
                          The outlet is roughly 62.25mm
                          The center is roughly 60mm
                          So... by machining, we are taking roughly 1.5mm out of the ends and 5mm or so out of the center.
                          To the think of the edge... if we were to machine a straight bore, we wouldnn't have to worry about the edge. For that matter, you would want a flat edge like the stock M20.
                            • 34844
                            you want to keep the venturi though.. especially with a 5mm bigger plate.
                            • rvaughnp
                              • 136
                              Is that something a machinist can perform? Its one thing to drill a hole, its another to drill a tappered hole.
                                • 34844
                                it's definitely possible. It looks like the one I have was done by hand though.
