Direct swap larger throttle body M20?
  • NC325iC
    • Mar 2004
    • 6565
    #31
    suddenly that adapter plate is looking alot easier to buy (aka machine) huh?
    I wonder what sort of difference having it spaced out an extra inch would have, i know people with american cars use TB spacers, just dont knnow why
      • 34839
      #32
      supposedly for more velocity, but I doubt it makes much difference.
      I don't think it's *that* hard to bore it out. Seriously, if somebody can do it in their garage by hand.. I got mine from bottlecape30.
      • NC325iC
        • Mar 2004
        • 6565
        #33
        i would set it up on a mill with a boring bar and do it if it were me, but like you said itd probly be benefitial to keep the venturi
        • rvaughnp
          • 136
          #34
          When i pick up my crank, i will ask my machinist what he thinks.
          I had the idea to ask a local water jetter if they could make the plate. I hope to remember to do it Friday.
          A couple of questions to be answered on the M50 body adaption:
          1) How would the vac lines get attached? 5 total.
          A) or do they need to be?
          2) How would the coolant line work?
          • Kershaw
            • 11822
            #35
            tb spacers are also a handy place to install nitrous lines.
            AWD > RWD
            • SpecM
              • Oct 2005
              • 4531
              #36
              I don't know what the theory behind TB spacers are, but my cousin's 350Z picked up a bit of mid-range torque with one. And I personaly drove it before and after.
              1989 cirrisblau-metallic 325i
              • digger
                • Nov 2005
                • 6147
                #37
                Originally posted by nando
                you want to keep the venturi though.. especially with a 5mm bigger plate.
                what function does the venturi have?
                • e30 sdw
                  • 261
                  #38
                  I invite all of you to come & check out my design in person @ BIMMERFEST! The benefits I have received are quicker throttle response with gains in the low end. I have also designed it to act as a velocity stack. I feel this is a much better improvement then just honing alone. I will have dyno charts @ the show with before and after. For the price and expense of doing all that to the T/B. My design is pretty hard to pass up. Not trying to lure you Im just confident that you will be satisfied with my design.
                  Through Inovation in safety, comes luxury of performance.
                  SUPERIOR DESIGN WERKES. www.vicsbimmer.com
                  • rvaughnp
                    • 136
                    #39
                    I can't make it to Bimmerfest... so how else would i be able to look at it?
                    • e30 sdw
                      • 261
                      #40
                      Check out my group buy thread, I have a few pics of it installed. The added space adds velocity, few ppl have riden in my car with pleased results. Dyno #'s to come.
                      • rvaughnp
                        • 136
                        #41
                        Will adapter allow the vac lines and the fluid line to be connected?
                          • 34839
                          #42
                          velocity, one would assume.
                          • e30 sdw
                            • 261
                            #43
                            Vacuum lines and booster, no pre-heater hoses. dont really need them going thru the T/B so I always bypass that. Complete bolt on, my kit will include everything you need to install.
                            • IRON-E
                              • 16548
                              #44
                              Woohoo.......I'm so looking forward to doing this to my car, unfortunately I didn't have luck looking for a M30 throttle body at the JunkYards in the morning. :(
                              @IRON-E30 aka Edwin:D
                              • Lunner
                                • 222
                                #45
                                What's involved in the bypass?
                                87 325iC 90 325iC 88 325iC 87 325i 87 325iS 87 325eS
