Hey r3v, so i finally got around to my turbo project. Anyway, I used one of those cheap eBay manifolds(smart) and forgot about having read that they block the oil filter. Anyway a oil filter relocation kit is on order but i wondered if a shorter oil filter exists that would thread onto and match up to the e30 m20b27 block. I know that some GM oil filters are interchangeable and are just different lengths. Does anyone know if this oil filter exists for the m20 and what number or what make and model is it off of?
Does a shorter oil filter exist?
you could also use a 99 Toyota Camry filterwww.CASTROMOTORSPORT.com
Castro Motorsport
12600 Sherman Way, Unit C
North Hollywood, CA 91605
818-765-3606
Follow Castro's on Facebook:
http://www.facebook.com/pages/Castro...02411516506828
Follow Castro's on Instagram:
http://instagram.com/castromotorsport#
Originally posted by Kershaw View Postif he has an m20b27, he does not have an oil cooler. but good advice regardless.
edit: now that I think of it, I'm not sure i'M thinking of the right car. So many cars, so many years, I kinda doubt myself these days.Last edited by browntown; 08-30-2010, 10:13 PM.
I need my AC so can't rotate the oil filter housing 180', I need the oil cooler for my 10:1 stroker, I'm using the sandwich plate for a few sensors.... and I'm trying to make RD header work....
not sure about Specs on Toyota filte as someone mentioned abover, but it loos like WIX 7503 is closes small filter that matches M20 Specs. OEM filter bypass pressure is 30psi, this one is 36psi, most filters out there are 8-12 psi. Max flow is a little under the giant stock filter is 7-9 GPM and this one is 5-7 GPM, which is still under m20 oil pump's capability which is about 3.5-3.75 GPM at 6500rpm. And the best part is only 1mm larges in diameter but it's 41mm shorter, yes 41mm.
Hopefully someone finds it useful..
Product SpecificationsPart Number: WL7503 UPC Number: 765809263642 Style: Spin-On Lube Filter Service: Lube Type: Media: Cellulose Height: 3.07 (78)* Outer Diameter Top: 3.03 (77)* Outer Diameter Bottom: Closed: Thread Size: 3/4-16 By-Pass Valve Setting-PSI: 36 Anti-Drain Back Valve: Yes Beta Ratio: 2=23 Burst Pressure-PSI: 276 Max Flow Rate: 5-7 GPM Nominal Micron Rating: 23
why do you need a sandwich plate? pressure sensor with built in switch for the warning light in stock location and temp in the oil filter housing bolt (drilled and tapped) is the simplest method.Last edited by digger; 02-01-2022, 10:26 PM.89 E30 325is Lachs Silber - currently M20B31, M20B33 in the works, stroked to the hilt...
Originally posted by digger View Postwhy do you need a sandwich plate? pressure sensor with built in switch for the warning light in stock location and temp in the oil filter housing bolt (drilled and tapped) is the simplest method.
