School me on the 731 head
  • acolella76
    • 2950
    After doing some more research on swapping a 731 head vs an 885 head... I am thinking the 885 head would be better?
    731 head which has much bigger inlet ports than the 200/Eta. It has the same sized valves as the Eta which are 40mm inlet and 34mm exhaust
    So... basically a 731 head is the same as me porting my 200 intake to 'i' specs and adding an 'i' cam?
    Most of the research i did was E30zone.. this link especially
    -Alex
  • blueapplesoda
    • Dec 2005
    • 1904
    you get higher compression with a 731 head than with 885, and the valves are near 885 size. This would be a proper "2.7i" utilizing higher compression. if you were to boost the motor than 885 would be a better choice, as it lowers the compression ratio.
    • digger
      • Nov 2005
      • 6194
      885 is a superior head than the 731, cop the small CR difference for a better flowing head
      • Gruelius
        • Oct 2009
        • 298
        what digger says, also 731 heads have 80mm bore so only works with ETA not seta
        RIP 84 323i coupe 5spd w/ 14psi
        89' 318i
          • 34844
          hmm? you talking about the combustion chamber size? M20B27 (eta and seta) and M20B25 are all 84mm bore, not 80mm. the combustion chamber of the 731 is the same as the 200, but of course you're still right that it won't work with seta pistons.
          • acolella76
            • 2950
            So basically, me spending the $275 for a 731 wouldn't really be worth it when I can get a rebuild 885 head for half that?
            I know the 731 won't work with the seta pistons. If i had them, or the money/time to put some in, I wouldn't have posted this thread
            -Alex
            • SpecM
              • Oct 2005
              • 4531
              I would personally use the 731 head and port it to use 885 valves and manifolds
              1989 cirrisblau-metallic 325i
                • 34844
                I would buy the 885 head and call it a day.
                • acolella76
                  • 2950
                  It would probably be a lot cheaper for me to just do that on my current head.. would it not?
                  And yeah I'm probably going to just slap the 885 head on. Maybe use a thinner head gasket to help with compression?
                  -Alex
                  • hotballs
                    • 1155
                    The 200 head is yes basically the same as the 731 head, minus the intake ports and the 7 oil journals vs. 4. So you would have to hog out the intake ports of the 200 head and drill the extra holes to lube the 7 bearing cam to make is a 731 head. Honestly not worth it if you can just start with a 731 head. Plus the 323i cam is "hotter" than the 885 cam.
                    The 731 valves and 200 valves are exactly the same. You can put i exhaust valves in the 731 head. There is enough room to grind the stock seat to add +2mm valves on the exhaust side, but only enough room to do +1mm on the intake side. After that you need to put in new seats. (You get a machinist to grind down the i intake valve 1mm and grind out the intake seat 1mm.) And port it. And $1000 later you'll still have a NA m20.
                    • Faviolosky
                      • Nov 2008
                      • 154
                      tell you what tell me where you are going to get it, and ill get it, then your left with one option, :-D:-D
                      no seriously
                        • 34844
                        the compression really won't be a huge deal - a few % loss. it's not like the stock B25 is a high-CR screamer. it will certainly wake up your eta motor either way.
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          This.
                          This.
                          ...and...this.
                          Losing .7:1 compression and gaining the flow and cam of the 885 head is definitely worth it, and not too bad on the wallet. ;)
                          john@m20guru.com
                          Links:
                          • acolella76
                            • 2950
                            Looks like I'll be going with the 885 head :)
                            Seems like it leaves me more options.. If i want more power I can easily boost it :D
                            -Alex
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              You won't be disappointed, click the vid link in my signature to see how my 2.7 runs after the 885 head and Motronic 1.3 ecu upgrades. Still has the stock 2.93 rear gears to boot ;)
                              john@m20guru.com
                              Links:
