Different AFM or MAF for M20?
  • M20power93
    • Feb 2011
    • 84
    Is there any different AFM's or MAF's you can use for the M20 motor to gain more power or make the engine more efficient? I know someone who put a larger MAF on an S52 and got noticeable gain. Is the same true for the M20? Obviously theres a big difference between the two..it's an M20B25
    • 34844
    the only thing in this category that's worth a damn is a MAF kit from miller. I think it runs about $300 with a chip.
    different AFM's without requisite tuning is a waste of time.
    and in any case, changing only the size of the air flow meter isn't going to significantly change power. Most of the gains from swaps like that come from the subsequent retune.
    • e30 gangsta
      • 3877
      ^ x2 with the war chip
      • DmcL
        • Apr 2009
        • 260
        theres probably tons of 0-5v outputting AFM's, MAF's, MAP's and maybe even variable TPS sensors for good measure out there that can be made to work and work good.. the issue is the tuning required to get it working. from what i have done so far and what i know/have seen about how the stock ECU works it looks like miller are only scratching the surface of all the possibilities.
        i have already had my own M20 running very well on one bosch MAF and idling/revving ok on a GM 1 bar MAP sensor.. i would maybe try a variable TPS and try it alpha-n style but mounting a suitable TPS would take a bit of head scratching and i havent even finished playing with MAF or MAP sensors yet.. nearly forgot, also had it running great on an M30 AFM also lol
        Currently E30-less
        - EthosMotorsports.com
        • manjambles
          • 125
          just installed my miller intake and chip, and yes it brought my m20 to life. 1-3 spin tire all day ( im building for drift so thats what i want). it also made the throttle way more responsive. best money spent!!!
            • 34844
            M30 automatic TPS from an E34 is a direct bolt on, still has the TP switches as well as the variable TPS. would work fine for alpha-N, not that I'd want to run alpha-N unless I had to..
            • downforce22
              • Aug 2009
              • 3192
              i was looking into the MAF system. Found this thread. From the site it looks like you need an adapter for the m20 (oout of stock :( )
              What kind of performance gains would this put out? Is the main reason for doing it the tune-able WAR chip combination? thanks
                • 34844
                miller will claim huge gains from the maf, but most of it is really from the tuning.
                • TimR
                  • Mar 2008
                  • 549
                  Look at all thier dynos and info, allmost all the info says * M30 TB and 2.5" performance exaust, So whats the #'s without doing another $300-500 in upgrades, one part has a plain jane HP pull, did a 3.5 bar FPR get added too?? If i told you my $1300 headers would give you 35 HP would you just buy them?? OOps you need a highflow Cat, Y pipe 2.5" exaust to a Eisermann muffler to get 35HP is that fair???
                  • downforce22
                    • Aug 2009
                    • 3192
                    thanks for the quick response nando.. I was looking into possible upgrades, the 6000 ft elevation takes away a lot of the power that I have/ want if I was a lot closer to sea level.
                    I'm not sure an ix would like this combo anyway, but then again assuming it has the stock chip it is basically a regular m20 and ecu, correct?
                      • 34844
                      yes the engine is no different
                      • Cyrix2k
                        • 593
                        Pretty much. http://www.youtube.com/watch?v=chhzV2O3nEA
                        Same tune, only difference is AFM vs no AFM and they picked up 3 hp/3ft lb torque. With the new tune and no AFM, +23 hp/+23 ft lbs torque
                        1997 540i/6 - stock
                        1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
                        1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
                        • brody
                          • Jul 2009
                          • 334
                          HAHA! the MAF won't even work without a tune you guys. OBVIOUSLY the gains come from tuning FOR the MAF becuase without the tuning, you would have a shitty driving car. That is why our conversions come with a chip and that is why we claim what our CONVERSION give in terms of power.
                          On our website is a bone stock M20 with JUST the MAF conversion.
                          http://millerperformancecars.com/fil...III%202.5L.pdf
                          This is just our normal GENIII MAF. Those who have actually installed our products can vouch our claims are not astronomically out of whack like many people think...
                          • browntown
                            • Jun 2004
                            • 3524
                            I don't remember the reasoning behind it but the using a m30 afm on the m20 was all the rage a couple years ago. Probably bigger opening.
                            • digger
                              • Nov 2005
                              • 6191
                              I think his point was that since the AFM is not a large restriction that doing a retune while retaining the AFM will give you 90% of the WOT gains i.e. the MAF part doesn't do much for WOT. Obviously there is more to performance than simply WOT runs but anyway.......
                              Brody, Where are the independant dyno tests for the M20?
