Bought a LOT of parts, need ID help
  • StereoInstaller1
    GAS
    • 22679
    Originally posted by Rc 415
    I found out its a metric mechanic head, and I will be using it on the 2.7 pictured above that I am tearing apart to rebuild.
    It will not work, sell it to me.
    Closing SOON!
    Thanks for 10 years of fun!
    • Rc 415
      • Jun 2011
      • 723
      I'm really not selling anything guys
      1987 Delphin 325IS
      LS1•TSP 228r• condor speed shop solid subframe, diff, fcab, mounts•Airlift air ride suspension•e36 ps rack•Eibach sways•16" Spal puller•bbk 310mm front & rear•17" BBS RS•
      Build Thread
      1993 alpine 2 325IC
      •Ground control coilovers•16" BBS RS• momo woodgrain
      • der affe
        Technical
        • Dec 2005
        • 8452
        you have an m tech 1 wing for either an e30 or e28. that white plastic thing fits inside the inner edge.
        now give me the head for identifying that for you.
        • hotballs
          • 1155
          That is an e36 3.2 LTL rack. The black manifold is 325i intake/TB/Fuel Rail, injectors could be anything.
          Take a larger picture of the crank, I'm just guessing 2.7 crank.
          I'll take the 885 head.
          How much did you get the whole lot for?
          • bernzpeed
            • 3917
            Let me know if you have other parts you might need.
            89 E30 S52
            Transaction Feedback.
            • ForcedFirebird
              • Feb 2007
              • 8300
              I told you on the bimmerest that the head looks like it might be a MM head, not that it definitely is ;)
              You will do much better to match that head to 2.5 or seta pistons, not sure how well the chamber swirl machining will have an effect on dished pistons.
              john@m20guru.com
              Links:
              • sweet6e30
                • Feb 2011
                • 531
                screw you on the e30 parts gold mine find!
                my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
                • Rc 415
                  • Jun 2011
                  • 723
                  I contacted mm and they verified, it's a sport head. Thanks for the insight. Also I'm going with custom pistons and using the 135mm m3 rods. Found out the crank is a e36/e46 325 75 millimeter stroke, going to use the stock 81mm crank or try and find a 86mm 328i crank
                  1987 Delphin 325IS
                  Build Thread
                  1993 alpine 2 325IC
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    No info comes up on the crankshaft when I google it.
                    You probably used the casting #.
                      • 34847
                      you lucked out on the MM head! I don't know what you paid for all that stuff, but the head alone was probably worth it..
                      FYI -
                      B25 cranks (M20, M50, etc) 75mm
                      eta 81mm
                      M52B28 84mm
                      S50B30 86mm
                      S52B32, M54B30 89.6mm
                      • Rc 415
                        • Jun 2011
                        • 723
                        Thanks for the info! I paid 650 for the lot plus other odds and ends
                        1987 Delphin 325IS
                        Build Thread
                        1993 alpine 2 325IC
                        • JCarp90
                          • Feb 2011
                          • 1759
                          I'll take 38. PM?
