Parts Differences between '88 to '90 325i Models???
  • AV325i
    • Jul 2008
    • 104
    Hi r3V,
    I have an 88 325i Convertible, an 89 325iX and a non-running 90 325i (used for parts now). How similar is the engine in the 90 to the other two? I'm guessing the iX is pretty different, but what about the convertible?
    I hope to replace the dashboard in the iX with the on in the 90. That should be a match, shouldn't it?
    I need an new muffler on my convertible, one of the short tail pipes rusted off, but I'm guessing the exhaust on the 90 won't work for the convertible (the 90 is a 4 door). Doesn't the exhaust disconnect farther up?
    I also am having some idle problems on the iX, so I was going to swap out some parts from the 90. Do you think those are all a match?
    Thanks. Just trying to lean. It's getting cold here in Minnesota, so I'm trying to plan as much as I can before I go out in the cold garage to work!
  • 416stroker
    • May 2008
    • 2448
    Originally posted by AV325i
    Hi r3V,
    The ix is different
    Will work
    4 doors and 2 doors do and im not 100% sure never owned a vert but I think they match
    Should
    84 318I Delphin RIP
    87 325IS delphin 24v Sold
    89 325 Alpineweiss
    • Kershaw
      • 11822
      i've never heard of the cabrio exhaust being any different.
      ix exhaust is however different! only thing different engine wise is the block and the oil pan on ix.
      AWD > RWD
        The IX in a number of cases will be the odd one out here. Most things from the 88 will swap to the 90 and vice versa.
        • Ceeker
          • Sep 2009
          • 2821
          I hear the oil pickup and pump a bit different only because of location.
            • 34844
            and the oil pump and pump drive and pickup tube and dipstic and engine wiring harness and cat section and and and...
            • Kershaw
              • 11822
              i lumped that in with the block and oil pan, since it's contained by those. :P
              and you forgot the brake booster.
              AWD > RWD
                • 34844
                if I wanted to list every unique part I may as well post a dump of the ETK. :p
