BMW vs AMC head
  • Cabriolet
    • 9620
    BMW vs AMC head
    many people ask the quest of what is the difference between the crappy AMC head vs the bmw head. well some say the ports are different sizes and such.
    when i pulled my head off my mtech i found that it was an AMC head so i replaced it with a 87 bmw b25 head. i was very surprised to find very little difference. the AMC head is very poorly cast. many rough spots and the top side of the head is ~3-4 mm shorter and makes it difficult to fit the seals in.
    as for the intake and exhaust ports. they are both the same size. though there is about 1mm deviation between the ports on the AMC head. meaning they arent all the same size. the intake side of the AMC head was cut smaller to fit an ETA engine, the bored for an "I" head. the chamber was also rebored to "I" specs. the BMW head has a better design on the intake ports, being a smoother line into the valve.
    please see the pics bellow to see the differences.
    thx, any questions? ill try to answer as i can.
    Much wow
    I hate 4 doors
  • digger
    • Nov 2005
    • 6191
    thats pretty terrible detail where they machine the roof of the port entry........the floor of the BMW head looks flatter which is good for flow around the short side
      • 37833
      Glad somebody finally took the time to compare the two. I would personally never use the AMC head whether it be in stock form or modified like the ones I sell.
      Grover Beach, California
      BimmerHeads.com
      • YAN-3
        • Jan 2004
        • 6018
        Oh wow I never knew about these AMC heads. Gonna do some searching now. Thanks for this.
        Learneded somfen new today!
        • Mr.SWISS
          • Nov 2005
          • 1251
          The cooling ports appear larger on the AMC head but with all the other epicfailz I would run away from this casting.
          Originally posted by 325Projectz
          don't listen to the diagram... listen to mr. swiss.
          :nice:
          • Northern
            I like cupcakes & sh!tboxes
            • 5279
            any particular way to tell which cars have the amc heads?
            Originally posted by priapism
            Originally posted by shameson
            • SkiFree
              • Jun 2011
              • 2766
              ^ The big AMC letters cast into the head where you'll normally find '885'.
              ADAMS Autosport
              • Cabriolet
                • 9620
                BMW head: right over the exhaust port #2 you will see 2.5 in raised number.
                the AMC and 885 are hard to see when its on the car, because the intake manifold blocks the view.
                Much wow
                I hate 4 doors
                • nebulous123
                  • Jun 2011
                  • 923
                  this is only for the B25 right? Noticed you didn't mention the B27.
                  '84 325e - "Elizabeth"
                  '87 325e (SHELL) - "Sleeping Beauty" - COMPLETE PROJECT PART-OUT - S54, 5-LUG, and MORE
                  • Northern
                    • 5279
                    and this is only a replacement head, not some loopy factory part, correct?
                    • bernzpeed
                      • 3917
                      i found an AMC head on the 89 325i vert that we parted out.
                      89 E30 S52
                      Transaction Feedback.
                      • Cabriolet
                        • 9620
                        im thinking it was a factory item, maybe bmw couldn't meet the demand and had AMC make them for them. there is just too many around to conclude that people changed heads.
                        Much wow
                        I hate 4 doors
                        • Mr.SWISS
                          • Nov 2005
                          • 1251
                          Interesting....
                          So far these have all came from M20B25's right?
                          :nice:
                          • bastianshaw
                            • Jan 2007
                            • 2210
                            Agreed.
                            • Sagaris
                              • Sep 2009
                              • 2243
                              You would expect the Spec E30 guys to have gone through and dynoed each one to see which is superior in stock form.
