Pulling an M20
  • ThisGuy310
    • Jun 2010
    • 433
    Originally posted by 5Toes
    I have read that MR 325 has used only the front engine lift point atleast twice with success. I have a powdercoated intake manifold, so I would rather not wrap a chain around that.
    That's asking for trouble IMO.
    • Pantless Spency
      It's McRib time!!!
      • Feb 2011
      • 7283
      i still say run it with the knock.
      but in the event that you do pull it, make sure everything you use to lift it is SOUND as hell. just take it one step at a time and don't make it more complicated than it is. make sure all accessories are removed as well. and whatever you do please don't smash your only good foot with an m20 ;D
      • lolcantturn
        • 4588
        Orly?
        this is trackjunkie21 with my motor. That's motor, trans and driveshaft
        never had a problem using the front hook..at least on an m50
        Originally posted by TSI
        OEM+
        • ThisGuy310
          • Jun 2010
          • 433
          Originally posted by lolcantturn
          Orly?
          Did I say it was impossible?
          The hook is held in place by the bolts used for the timing cover, if I recall correctly there is a 13mm and a 10mm holding that cover in place.
          Do whatever you want, I don't give a shit.
          • e30austin
            • 15382
            Originally posted by Jparkr
            Andew... I don't think you have the capabilities to do this, just save up the money and pay a local shop. This isn't going to be like anything you've experienced before. I mean, you have had some trouble with some pretty basic stuff already and this is a lot more intense and in-depth.
            That being said, im sure you'll try it anyway so good luck, take things slow and use your head.
            This.
            • 5Toes
              • 9836
              Well everybody has to start some where. I kind of see this as my chance to prove to R3V I can actually fix something on my car.
              • e30austin
                • 15382
                Word. I didn't know shit when I was 16, going on 19 in a couple weeks and have learned a lot in the last 3 years. It's just a really big job and not for the faint of heart at all. I'm kinda dreading my M30 swap in a way, just because of all the work involved, but it will be worth it in the end!
                Anyway, like jparkr said, take your time and you'll be ok.
                • Danny
                  • 14216
                  • 5Toes
                    • 9836
                    Im not going to rush it. No reason to, I dont need the car.
                    I have a bentley, I have R3V, I have some friends to help, dont need much more.
                    When the day comes to get the new engine (likely next weekend), any PNW'er is invited. I will buy some pizzas
                    • Keith M
                      • 2338
                      Use the rear lifting eye, it's there for a reason. I've pulled 3 and didn't use a leveling device although I would imagine it would make it a little easier.
                      • Vivek
                        attention whore/retard/bitch
                        • 6167
                        You'll be fine. Fuck the haters.
                        1992 Mauritiusblau Vert
                        2011 Alpinweiss 335is coupe
                        2002 540i/6 Black/Black
                        2003 GSX-R 750 (RIP)
                        • 5Toes
                          • 9836
                          Thanks the advice Keith. Pulling the intake manifold isnt that hard. I can probably do it in 30 minutes now that I know how.
                          • Jand3rson
                            • 37587
                            Jack the rear end of your car as high as you can get it on jackstands, and jack the front up just high enough so you can get jackstands under it, so the whole car is raked foward, it will make pulling the motor up and out much easier.
                            • 5Toes
                              • 9836
                              Thank you for the solid info Josh.
                              And do you recommend using the rear location too?
                              • Thrizzle
                                • Aug 2011
                                • 194
                                I wrapped one long chain under the passenger side motor mount arm, looped it over the valve cover and manifold, and looped it under the driver side motor mount arm. I had a load leveler, but I didn't even use it for it's function. It allowed me to mount the chains perpendicular.
