Bullet Ride's 2.8L Stroker Project (Updated: Dyno Plot pg. 6)
  • Ether-D
    • Sep 2011
    • 2838
    #121
    What did your parents do (or not do) to make you such a badass? I've got three kids that I want to become doers.
    Beautiful build. I'm doing the m50b28 crank and e rods right now on my spare motor.
    Really inspiring...
    Originally posted by Andy.B
    I was born on 3/25…
    • Bullet Ride
      • Dec 2010
      • 598
      #122
      Really inspiring...
      haha, well my old man is a definitely a handy man. I remember hanging out in the garage with him when I was young handing him tools while he worked on the family car. That definitely played a part. Also, me and my two brothers were always interested in tinkering with mechanical things when we were kids, whether it be our bikes, or taking apart our toys (and never quite getting them back together properly lol). Suffice it to say, we all ended up going to university for mechanical engineering
      • Ether-D
        • Sep 2011
        • 2838
        #123
        Then my kids are on their way...
        Again, great write-up.
        I was born on 3/25…
        • cgk_iii
          • Dec 2012
          • 616
          #124
          all the pictures dont show up on my mac anymore.. :( now its just a bunch of photo bucket bandwidth crap.. ive been following this thread for a while now too..
          • Bullet Ride
            • Dec 2010
            • 598
            #125
            Yeah, my 10gb bandwidth limit got maxed in two short weeks.... too many people are looking at my build threads lol.
            I need to start hosting my pictures somewhere that has more bandwidth.
            In the meantime, you can just right click on the picture and select open image in new tab if you want to see it. Bandwidth is unlimited if viewing the pictures directly on the photobucket website.
            • darvo
              • Dec 2010
              • 407
              #126
              What compression ratio would your engine have with that setup?
              • Bullet Ride
                • Dec 2010
                • 598
                #127
                It hasn't been verified but I calculated it to be somewhere between 9.7:1 and 9.8:1
                • cgk_iii
                  • Dec 2012
                  • 616
                  #128
                  Hey, had a question regarding the way you machined the crank. Do you think you could have gotten away with taking material off the piston skirts in order for the crank to fit or do you think machining the counterweights was your best option?
                  • Bullet Ride
                    • Dec 2010
                    • 598
                    #129
                    Apparently it's been done that way before. I think part of it depends on which crank you have because there are a couple different 2.8L cranks. The best way to find out is to put a rod and piston on to the crank and take some measurements.
                    • digger
                      • Nov 2005
                      • 6188
                      #130
                      in this pic it is shown with a 135mm rod so a 130mm rod would mean the crank counterweight would foul the piston boss as well as the skirt. machining the boss away is not recommended. note that not all counterweights are the same radius either so some may sneak in others not.
                      • Bullet Ride
                        • Dec 2010
                        • 598
                        #131
                        http://www.r3vlimited.com/board/show...4&postcount=46
                        wow... that looks ghetto as f**k! lol
                        • digger
                          • Nov 2005
                          • 6188
                          #132
                          yep, had heaps of spare scuffed pistons and it was the easiest way to check clearance with a much much bigger crank;)
                          • Reichart12
                            • Aug 2012
                            • 2165
                            #133
                            Hey sweet build and that sound is great. Im building an engine kinda similar to this and have a couple questions if you don't mind. What injectors are you running? And when you built the exhaust did you use a flew pipe or just headers to mid and the rest?
                            Instagram: Reichart12
                            • cgk_iii
                              • Dec 2012
                              • 616
                              #134
                              Wow ok, that makes things a lot more clear. What is the recommended process then? Every machine shop I've talked to about taking material off the counter weights, look at me like I'm speaking a different language. I have access to a lathe, but I think the crank is a bit too long to fit. We have a big lathe at school but my "high performance" teacher thinks machining the crank is not the right way as well. Really don't want to spend $600-$1000 on custom pistons if I don't need to.
                              • digger
                                • Nov 2005
                                • 6188
                                #135
                                basically you need to find one that can machine it, and get everything balanced again. machining the crank isn't the right way but it is probably going to be your most economical way
