Newly rebuilt M20 AFM - $70 (Standard MF20040) NOT a forsale thread
  • noid
    • 1537
    A rebuilt Bosch unit ( 0 986 280 003) is $244 a new one being $356.
    However apparently Standard (Borg Warner/BWD) also makes a rebuilt AFM unit for the m20 model number MF20040. Which can be had for ~$70 at advanced auto parts.
    Anyone every heard any good or bad things?
    Here in canada its sold under the bluestreak line (www.Bluestreak.ca).
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
  • dnguyen1963
    • Nov 2011
    • 2651
    Here is the part # in the US...
    • DetailAddict
      • Apr 2011
      • 245
      nice find, thanks!
      • noid
        • 1537
        Would be cool to see someone open one of these units up to see just how well they were rebuilt.
        • dogsbark26
          • Nov 2008
          • 533
          Originally posted by dnguyen1963
          dnguyen1963, have you used one of these? Works good?
          • IAmGary
            • Apr 2012
            • 183
            I am super skeptical of any remanufactured AFMs, see my thread on the topic here: http://www.r3vlimited.com/board/showthread.php?t=256293 However, $72.00 is half what I paid for the Python remanufactured unit so perhaps it's worth taking a chance just to see?
            • Gregs///M
              • Mar 2012
              • 2459
              I rebuild AFM's. Check my thread here. http://www.r3vlimited.com/board/show...83#post3152483
              It is my opinion that most of these "parts warehouses" take a AFM from a known running car. Sandblast the outside, repaint, clear coat, and re-sell these units. I doubt they go through the extensive electrical testing that I put mine through. I also clean every electrical contact point and verify operation on my oscilloscope. Each customer receives photos and o-scope printouts of their personal AFM.
              Owner - Bavarian Restoration
              BMW and European Electronics Repair and Restoration
              www.BavRest.com
              My Feedback Thread
              Our Facebook!
              Follow our Instagram!
              • IAmGary
                • Apr 2012
                • 183
                The problem with one of the AFMs I got from Python was not that it failed electronic testing but the connector wouldn't physically seat correctly. That's something the re-manufacturer wouldn't know unless they hooked it up to a car and ran it.
                Gregs///M, how do you test the devices to ensure that it's really going to work properly? I think there's more to a part than just operating within acceptable electronic parameters. I'm not asking this to challenge or disrespect you in any way but because I'm in the market for an AFM and want to know that I'm going to get something that will work before I put up cash + shipping (for a third time).
                • iansane
                  • 1342
                  How would the 'parts warehouse' know the core unit coming in for rebuild was a from a running car?
                  84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
                  • noid
                    • 1537
                    I am not sure if I would call bending the arm and cleaning the electrical points to be a rebuild.
                    An oscilloscope is more for you to confirm you didnt mess up the bending of the arm before sending it back to someone.
                    I am almost certain all the rebuild places also use an oscilloscope after their rebuilds.
                    The thing I want to know is if if the blue streak/BWD units have new boards, instead of a bent arm.
                    Pyton =/= BWD. As far as I know the BWD units are rebuilt here in Canada at one of their facilities.
                    @IAmGary: Since you can get the BWD unit from your local auto store, try it out the worst that can happen is that you will return it for a full refund.
                    • Gregs///M
                      • Mar 2012
                      • 2459
                      My AFM's are all tested and use the same 4 pin connector as per the Bentley manual. I suspect you were send an AFM from a vehicle that was not compatible to yours. If it was the correct connector, and did not seat, there must have been physical damage to either connector.
                      Each AFM is tested in a variety of ways. As per my ad, the inlet air temperature sensor is tested throughout its range. The electrical contacts are not just adjusted, but disassembled and cleaned. Once re-assembled the internal spring tension is tested vs a know good and recently refurbished AFM that I have acquired from Fuel Injection Corp. This spring tension is a very tight tolerance set by Bosch that uses a laser calibration method.
                      Finally, each AFM is tested through the oscilloscope. There is NO better way to check the voltage feedback of an AFM. Not even a running car. The voltage is verified throughout a time scale and results captured by the oscilloscope. Any drops in voltage or non linearity would should up and we be justification for failing the AFM. Please read my ad for more details of the electrical feedback testing process. It is tested for repeatability in both the high throughput and low throughput (high speed and low speed air input.)
                      An oscilloscope capture "Verifies" voltage feedback as per unit Time. If the AFM was non working or developed some sort of deviation from its normal feedback, the o-scope would catch it. My rebuilds are much more than just bending the arm and cleaning the contacts. All sensors and tension are verified vs a known fresh rebuild. In addition, since their feedback is verified through several cycles, it is proof of their working operation.
                      The Bosch AFM has long been discontinued and I highly doubt they would trust anyone but their own testing standards to rebuild the AFM. Just unloading the spring, would require complex laser calibration from Bosch. For this reason, I do not re-sell any AFM that has its spring disassembled, modified, or removed.
                      www.BavRest.com
                      My Feedback Thread
                      Our Facebook!
                      • noid
                        • 1537
                        I find it odd to say you do much more but then confirm that all you do is verify the results. You admittedly can not do anything about the spring tension nor do you replace any parts. Bending the arm on a shaped curved to be lower or higher on the strip also creates a shorter/longer travel of the sensor thus setting it off spec as small as that may be in your opinion.
                        If any company could afford laser calibration equipment it would be a company the size of borg warner. For all I know the Borg warner unit is as shit as shit can get; hence this thread to see if anyone has any feedback.
                        You do a very good job of fluffing the wording about about what you do, but in my opinion you do very little for the price requested. My father has his Masters in Electrical Engineering and has 30 years experience. Luckily I have had the privilege of seeing him build (eg, ham radio from scratch), rebuild, and repair electronics. Don't get me wrong I know jack shit about electrical engineering. That being said if I can EASILY understand what you are doing and classifying as "rebuilding" you are hardly doing more then bending, cleaning, and verifying.
                        I think in honour of this thread people can simply watch these videos:
                        and "rebuild" their AFM's themselves.
                        • Gregs///M
                          • Mar 2012
                          • 2459
                          NO one is holding a gun to you head and making you buy my AFM's. Call it what you want but my customers have all but provided outstanding feedback on the AFM's that I sold. They have shown results that fixed and improved their drivability. For the price, often around $100 shipped, its a very convenient and affordable option for those not familiar or capable of rebuilding their own AFM's.
                          The same deal goes with my SI boards. I'm sure many r3v members can change their own SI board batteries but I provide this service to help out the community for those not capable of doing it themselves.
                          Just because you can EASILY understand what is going on in the AFM rebuild, does not mean Borg Warner runs some highly complex rebuild service. You need to realize the structure of the AFM is well over 20+ years old and very simple in nature. It does not take an Electrical Engineer like your dad. But much like your dad, I am a electrical engineering technician for over 10+ years and highly qualified in the work I do for the community.
                          I've also rebuilt AFM's and measured their output on my o-scope only to find that they did not pass my test because of voltage drop out. An o-scope should be a tool used to repair AFM's, at bare minimum or else you could be installing an AFM that performs worse. Does everyone have an oscilloscope? no.
                          So like you said, VERIFYING is the key to a successful AFM rebuild. Who would want to buy an AFM that is not VERIFIED working?
                          If you are so concerned about your AFM build quality, just buy a new one from Bosch.
                          www.BavRest.com
                          My Feedback Thread
                          Our Facebook!
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            Testing and repairing an AFM is simple. Here's a site that's been up for some 11yrs regarding the subject using nothing more than a 9v battery and a DVM to test an AFM...
                            the944.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, the944.com has it all. We hope you find what you are searching for!
                            Yes, it's a Porsche site, but since they also used Motronic 1.3, it's the same thing.
                            john@m20guru.com
                            Links:
                            • noid
                              • 1537
                              Well lets not forget I started this thread :-D, and surely I am not being forced into buying anything.
                              Electrical engineering technician =/= Professional electrical engineer.
                              I agree that even though Borg warner has the capital to invest in proper equipment that does not mean they have actually invested in it. I am 100% certain they at least have a simple device like an oscilloscope to test the units post rebuild. So they ARE verified as far as I am concerned; I couldn't imagine a company that size blindly selling maybe-working units. In any case, the BWD units can be returned to a local parts store for 100% refund.
                              Python is another story, look here:
                              This is their HQ, does it look like a place that is competent or has the proper amount of capital to be able to rebuild AFM's? I wouldn't trust them, thats for sure.
