I'm afraid you are the one who incorrect. But hey, here is your opportunity to prove me wrong in front of everyone in this forum.
A DVM does not nearly acquire voltage signal as fast as a oscilloscope. Let me explain this the best that I can.
Let's say we want to test for bad AFM. Customer reports they have severe "bogging" at idle speeds. So let's test with a DVM vs an oscilloscope.
DVM:
Measure voltage output while the wiper arm is moved from fully closed to half open. The DVM does not have the resolution of an oscilloscope so its averages the voltage over the time acquired. BTW, in general, DVM acquire voltage using three methods...max volts, minimum volts, and average volts. The DVM is going to provide you an average of the voltage acquired.
Therefore, with a DVM, the voltage feedback would appear to be within spec and you pass the AFM and return to the customer. Customer spends hundreds of dollars replacing other items and troubleshooting, etc.
Oscilloscope:
Measuring voltage output while the wiper arm is moved from fully closed to half open and displays this voltage difference over a time scale of say...10 seconds.
This graphs shows myself opening and closing the AFM from 0% to 10% nine times in a period of 10 seconds.
Notice the "dips" to zero volts. This is known as voltage drop out and is the reason why there is a sudden loss of power near a specific RPM range, which correlates to a certain speed range or air input to the AFM.
Also notice on the second curve that voltage drop out occurs near the beginning of travel and near the end of travel. It happens several times more over the period of 10 seconds.
But note: these drops to zero occur and only last a few milliseconds and even microseconds! A DVM CANNOT ACQUIRE NOR DOES IT HAVE THE RESOLUTION TO CAPTURE THESE MILLISECOND DROPS TO ZERO VOLTS.
I would fail this AFM and the customer would rest assured that he has found the problem to the solution.
So please, anyone reading this. Please understand a DVM is not sufficient to test a AFM. At bare minimum, a oscilloscope or data acquisition software must be used which has a resolution of microseconds or better. My oscilloscope can acquire data at a rate of Pico-seconds so it is more than sufficient to test accurately.
ForcedFirebird, you're welcome to dispute my research and findings. Please enlighten us.
DVM:
Oscilloscope:
