E to I wiring
  • dougie30
    • Apr 2012
    • 1708
    ohh ok i understand, so if i cant find an 87 harness, is there a wright up on how i should mod the later harness? or is every thing i have to do to mod it, in your first post?
    M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
    • dnick
      • Apr 2011
      • 1377
      does anyone know what pin/wire to splice the c104 tach wire into? 84 to 89
        The tach signal is the blue/black wire from pin 6 of the DME connector. The econometer is a white wire from pin 32 and the START input is the green wire to pin 27.
        • dnick
          • Apr 2011
          • 1377
          thanks a lot !!!
          • dougie30
            • Apr 2012
            • 1708
            could someone find a write up on how to modify the harness? iv searched and have not found any thing. just a few people asking for certain wires here and there
            Please help!
            • Supratreo
              • Aug 2016
              • 135
              :ohi, sorry to bring this back from so long ago but I'm a little confused and needed some help.
              I'm doing a complete I conversion on an 87 E. Basically converting the car to a 325i, right now I'm not sure but I believe I have a 90 harness so it sounds like it won't be PnP. Is pin 20 the only thing I need to worry about? A lot of people are saying the harness needs to be modified which sounds like there's a lot more to it but just modifying one pin is easy enough. Is it that simple or are there some pretty extensive modifications that need to be made that im missing?
              Thank you
              • varg
                Florida Turbo Man
                • May 2014
                • 3379
                Found this here: http://www.r3vlimited.com/board/showthread.php?t=192882
                1990+ 325i
                1. Charge - Bu - ?
                2. oil level - gn/yl, bu/bk - signal
                3. .
                4. coolant temp - br/vi - signal
                5. oil pres - br/gn, bk/br - signal
                6. oxy heat - gn/wt, gn/yl - +12v
                7. ignition coil - gn - +12v
                8. fuel rate (econo)- wt/bk, yl/wt - signal
                9. tach signal - bk - signal
                10. oil level - bu, vi/gn - signal
                11. inspection reset - wt/gn, wt/bu - signal
                12. check engine - gy, br/bk - signal
                13. fuel relay - gn/vi, vi/red - +12v
                14. speed - bk/wt, bu/yl - signal (from instruments to ECU from cluster C2 Pin 10 bu/yl)
                15. unloader - bk/gn - signal
                16. srs - wt/bkv -not used
                17. ABS Communication - bk/yl - signal (325ix only)
                18. starter - bk/yl - +12v
                19. .
                20. ABS power - rd/yl - +12v
                And this:
                1987 325i
                1. Charge - Bu - ?
                2. oil level - bu/wt, bu/yl - signal
                3. .
                4. coolant temp - br/wt, br/vi - signal
                8. .
                9. .
                10. oil level - bu/yl, vi/gn - signal
                11. inspection reset - wt/bu - signal
                12. check engine - br, br/bk - signal
                13. fuel relay - gn/vi - +12v
                15. .
                17. .
                19. .
                20. .
                I did not see the '87 325e listed so I looked at the ETM and verified these:
                1987 325e C101
                1. Alternator excitation, bu
                2. Static oil level, bu/yl
                3.
                4. Coolant temp gauge, br/vi
                5. Oil pressure light, bk/br
                6. O2 sensor heat, ECU power, gn/yl
                7. Ignition coil power, gn
                8.
                9.
                10. Dynamic oil level, vi/gn
                11. Inspection light reset, wt/bu
                12.
                13. Fuel pump relay, gn/vi
                14.
                15.
                16.
                17.
                18. Start, bk/yl
                19.
                20.
                Safe to say the '87 e and i C101 pinouts are the same imo. Also have a look here: http://www.r3vlimited.com/board/showthread.php?t=100939
                IG @turbovarg
                '91 318is, M20 turbo
                • TobyB
                  • 5243
                  pin 20 of C101 on the body side of early cars is grounded and as I recall there isn't a wire to 20 on the harness side. But on later cars that pin has some other function and isn't grounded.
                  Yes, as above, on late cars, pin 20 is +12 at 20+ amps for abs or airbag.
                  Even though the body side doesn't say it, 20 is usually grounded with
                  small diameter wire.
                  When you turn things on, the small body wire starts smoking.
                  ALL YOU HAVE TO DO IS CLIP PIN 20. It is absurdly easy.
                  Then the car will start and run.
                  You'll have to move 2 other wires to get tach and something else, but that's not
                  too hard.
                  This isn't rocket surgery.
                  t
                  • Supratreo
                    • Aug 2016
                    • 135
                    thank you guys very much for clearing that up.
                    i thought it would be that easy.
                    as far as the inside goes, isnt there 3 wires you need to splice? tach, CEL and i believe the eco. gauge.
