will standard m20 motor be compatible with auto tranmission
  • e30wavee
    • Jun 2012
    • 36
    hey everyone need some help I bent valves in my m20b25 due to a bad timing belt ive been going crazy looking for a motor with low miles and I just found one in months of hunting for one. only thing is It came out of a 5spd and my car is a automatic would the motor bolt up to my automatic transmission ?
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Yes.
    • 5Toes
      • 9836
      Yes. Just gotta remove pilot bearing
      • efficient
        • Feb 2012
        • 3312
        if i have a automatic motor i have to add a bearing right?
        i have a manual trans.
        • gearheadE30
          • Jun 2007
          • 3734
          Yep. The crank is already drilled for it, so you just have to buy the bearing and press it in.
          Project M42 Turbo
          • efficient
            • Feb 2012
            • 3312
            thank you!
            • bostonvert
              • Oct 2015
              • 233
              Can anyone clarify what this bearing exactly is?
              Instagram : makeitsnap
              1985 e28 520i
              • 101
                • Jul 2011
                • 764
                Pilot bearing?
                It sits in the end of the crankshaft and supports the input shaft of the manual transmission. It is not used with an automatic transmission.
                It's part #1 in the attached. (7/86 eta car example shown)
                http://www.realoem.com/bmw/enUS/show...diagId=11_1937
                101
                The E30 collection:
                1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
                1987 325is - Delphin / Black Sport (son #3's)
                1987 325i Convertible - Triple Black
                1989 325iX Coupe - Diamondschwarz / Black Comfort
                1990 325iX Coupe - Sterling Silver / Grey Sport
                1981 Fiat 124 Spider 2000 - Green / Tan
                1998 Volvo V70 GLT - White / Tan
                1998 Volvo S70 T5 manual - White / Taupe
                2001 Ford Windstar - Silver / Grey (parts hauler)
                2006 Lexus GX470 - White / Tan (tow rig)
                • TobyB
                  • 5287
                  this.
                  t
                  • YosemiteSam
                    • Apr 2011
                    • 1303
                    If you get a new clutch kit the pilot bearing comes in the kit. A new clutch is cheap enough that you really shouldn't put a used one in, while you have it all apart just do the clutch job and resurface the flywheel.
                    • bostonvert
                      • Oct 2015
                      • 233
                      Originally posted by 101
                      Pilot bearing?
                      Originally posted by TobyB
                      this.
                      t
                      Thanks a lot guys, I never stop learning stuff on these old bmw's!
                      1985 e28 520i
                      • bostonvert
                        • Oct 2015
                        • 233
                        In the process of an engine swap (my car is a automatic) but I bumped in to a small issue :
                        The donor engine is a manual, the problem is that the torque converter does not fit the manual engine. There is an extra bearing for the manual transmission. Does this mean I have to change out the crankshaft? It doens't look like it is possible to remove the bearing.
                        This is the automatic engine
                        And this is the manual engine
                        1985 e28 520i
                        • jeffnhiscars
                          • Jun 2011
                          • 6011
                          You remove the bearing and reinstall your auto trans torque plate. If you dont have a bearing puller stuff the hole full of greaseand use a drift close to the size of the hole.
                          Alice the Time Capsule
