Correct valve clearance m20. Solution to ticking e30
  • whodwho
    • Jun 2008
    • 1547
    #61
    High mileage engines can have dished valve stems and gives a false measurement as the feeler gauge bridges the dished part.
    There isn't much you can do when like this other that use a dial indicator or compensate gauge thickness for the rocker ratio and use the feeler gauge on the cam lobe.
    Also to be clear on the post title, there will always be "ticking" with manually adjusted valves
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • digger
      • Nov 2005
      • 6182
      #62
      rocker ratio is approx 1.5 when on base circle so measurement at the cam should be 0.0065-0.007".
      here is a plot of the inlet opening and exhaust closing ramps at overlap. you can see that if you go looser than 0.25mm on inlet you are starting to shock the valve train more than the cam is designed to have and that will be noisier, even below 0.25mm should be noticeably quieter, however on the exhaust you could go to 0.3mm and youre still on the linear ramp portion.
      you can also see that adjustments in clearance will affect crank angle-lift areas slighty which potentially could improve midrange and top end power a smidge at the expense of bottom end power and idle quality (slightly). going to 0.20mm gives 6 degrees more seat-seat duration.
      you would be better off with a larger duration cam with proper clearances as there would be much better crank angle-lift area for the same seat to seat duration but ofcourse this cost money compared to simply using a thinner feeler gauge.
      • jeffnhiscars
        • Jun 2011
        • 6011
        #63
        How does anyone know this without their brain exploding :)
        you can also see that adjustments in clearance will affect crank angle-lift areas slighty which potentially could improve midrange and top end power at the expense of bottom end power and idle quality (slightly). going to 0.20mm gives 6 degrees more seat-seat duration.
        Alice the Time Capsule
        • FrostedE30
          • Jul 2015
          • 18
          #64
          Well my engine has more than 200k miles so I think .007" will be too tight an burn a valve, so do you guys think adjust at the cam at .008" for intake and .009" for exhaust would be okay?
          • digger
            • Nov 2005
            • 6182
            #65
            how the hell are you going to burn a valve at 0.007" lol
            • FrostedE30
              • Jul 2015
              • 18
              #66
              that doesn't really answer the question lol. So what would your recommendations be? I've adjust my valves at the eccentrics @ .010" but it still ticks pretty loud.
              • digger
                • Nov 2005
                • 6182
                #67
                0.008in/0.009ex will be fine, wont idle as nice though. but has zero risk of burning valves.
                • BMWManiac
                  • Dec 2010
                  • 1091
                  #68
                  How often do you adjust the valves? Every time you do timing belt? Every year? Every 30k/60k miles?
                  1997 Artic Silver M3
                  CES GT4094r 651hp/615tq @ 24 psi
                  • estoguy
                    • May 2013
                    • 1087
                    #69
                    Valve adjustment check is every 15 K miles (24,000 km).
                    You might want to refer to this thread: http://www.r3vlimited.com/board/showthread.php?t=364705
                    Estoguy
                    • FrostedE30
                      • Jul 2015
                      • 18
                      #70
                      wont idle as nice as the valves being adjusted to .010"? or because it's adjusted to .008"in and .009"ex? Sorry for asking so much questions.
                      • digger
                        • Nov 2005
                        • 6182
                        #71
                        in general tighter settings degrade idle quality a little bit especially running on stock motronic. The sky wont fall down but its noticeable/perceivable. having slightly different inlet and exhaust settings is not inherently an issue
                        • richardb
                          • 2121
                          #72
                          Here's a quick video guide I just made! Hope it helps.
                          Transaction Feedback!
                          • SLEEPYDUB
                            • 658
                            #73
                            Originally posted by RobE30
                            .Does having a Schrick 284/272 cam make a difference at all? I'm planning on refreshing the valve train next winter so I'll be replacing worn components then (unless something is really whacked out)
                            Looking for answers to this quesiton. I am running a 280/274 cam and after putting the head on and setting to .009 the engine barely runs at all and is ticking like crazy. Please advise
                            - AXIS POWERS - 2JZ E30 Build
                            Current Project - 87 325is 2JZ Swapped with M4 DCT
                            • digger
                              • Nov 2005
                              • 6182
                              #74
                              schrick recommend 0.25mm. i would set it at that. if it doesnt run properly (and the clearances are set correctly)there is some other issue(s) you need to start looking for/diagnosing
                              • ELVA164
                                • 4861
                                #75
                                Originally posted by nickmcc92
                                Wait, who is dyno?
                                lol
