M20 Noob Question
  • stonea
    • 2890
    M20 Noob Question
    Sorry if this has been asked and answered before, but I searched and really couldn't find a straight answer for all of my questions.
    So basically my question is there any difference between the:
    M20 from a 325i
    M20 from a 325ic
    M20 from a 325is
    M20 from a 325ix
    M20 from a 325e
    M20 from a 325es
    I know the M20 in the 325e is a 2.7 liter, but is there any other difference and I've hear the term short-block and long-block thrown around, but I was just curious whats different between them. I'm looking to replace the engine in my 325ix and I know its different, but I think thats just the oil pan.
    -Stone
    My Garage
    Feedback
    Instagram: Stone.Hopkins
  • Cletonius
    • 2809
    I am pretty sure you didn't search hard enough :p
    - Josh
    1990 325is
    Need a shift boot?
    Looking to buy shift boot frames, PM if you have one to sell
    Here's what happens when you let the internet pick your license plate
    • SkiFree
      • Jun 2011
      • 2766
      good intro
      So what exactly are the differences between a 325e and 325i? Why do some models have an “s”, like a 318is, 325es, and 325is? Is the ’84-’85 318i the same as the ’91 31…
      ADAMS Autosport
      • nomansland92
        • 1657
        M20 Noob Question
        Put a 325ix motor back in end of story. Btw the block is Ix specific, not just the oil pan.
        IX being restored here
        Ix turbo build here
        • stonea
          • 2890
          Thanks for the links and info guys that pretty much answers anything I had to ask. Also I would like to just put another ix engine in. I'm just gathering all my info before I make a decision or start the project.
          My Garage
          Feedback
          • nomansland92
            • 1657
            people have put I motors in Ix's but its a hassle from what I've heard. Whats wrong with your current motor?
            Ix turbo build here
            • stonea
              • 2890
              Nothing is wrong with it, my plan was to pull the motor and build a stroker motor then put it back in, but have a cheap M20 to just stuff in so I could keep driving the car while I built the stroker.
              My Garage
              Feedback
              • Poorboyz
                • May 2012
                • 2117
                Short block - engine block and head, nothing else.
                Long block - engine block, head and all the acc...power steering pump alternator, etc...
                If I were you I would research and learn a lot more than you know right now. Rebuilding an engine isn't a simple DIY.
                Sent from my Galaxy Nexus using Tapatalk 2
                Rebuilding since 07/06/2016
                Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
                Poorboyz Feedback Thread
                • SmokeE30
                  • 1730
                  Short block usually refers to just the bottom end assembly(block and rotating assembly) and long block usually refers to the short block plus the head/heads. A complete motor will come as expected with intake and accessories ect.
                  Shawn @ Bimmerbuddies
                  Bimmerbuddies LLC
                  717-388-1256
                  2971a Roundtop Rd, Middletown PA 17057
                  bimmerbuddiesllc@gmail.com
                  • Kozworth
                    • May 2011
                    • 1339
                    Originally posted by stonea
                    So basically my question is there any difference between the:-Stone
                    M20 from a 325i
                    M20 from a 325ic
                    M20 from a 325is
                    /\ All same internals, stroke 135mm, block, etc.
                    M20 from a 325ix
                    Different block, pan, etc.
                    M20 from a 325e
                    M20 from a 325es
                    Same block as the 325i/ic/is, same bearings internally according to realoem, different pistons, different rings, shorter rods 130mm, different crank.
                    • nomansland92
                      • 1657
                      Originally posted by Kozworth
                      M20 from a 325i
                      M20 from a 325ic
                      M20 from a 325is
                      M20 from a 325ix
                      M20 from a 325e
                      M20 from a 325es
                      The main bearings are different actually. http://www.iemotorsport.com/bmw/E30-...m20mnbrng.html
                      Ix turbo build here
                      • stonea
                        • 2890
                        I'm definitely going to do a lot more research before I even attempt at buying parts. Also I'm planning on doing this further down the road. Probably in two years or something.
                        Also thanks for clearing everything up guys.
                        My Garage
                        Feedback
                        • SmokeE30
                          • 1730
                          Pretty much with an ix you are gonna have to get quite a few parts from other ix's since they have so many awd specific parts. Also expect those ix specific parts to cost more and be harder to find that the non ix versions.
                          Bimmerbuddies LLC
                          717-388-1256
